I am having a small problem with the test menu enter button not working on my JD.
Recently a message has appeared on the DMD. Open coin door and operate test button, or words to that effect. There is a beep noise followed by the message.
Over the weekend I opened the coin door and found the enter button does not operate the menu function.
The button tests fine and I reseated the plugs on the card.
I tried again a day later and was able to get to the menu, then later in evening the beep followed by the message, followed by button not operating.
Tried again tonight and same. Accessed the menu, tried again 15 minutes later, no menu.
The volume and credit work fine.
Cheers in advance.
