So there is a huge black box in the middle of your playfield, want that gone? Then you just need this mod.
We've designed a way to move that switch to a hidden location under the ramp. The solution is plug and play. There are two screws to remove the old switch, that's it. Everything you need is included. The switch is entirely replaceable if you ever need to and is a generic pinball part. The connections are all made for you, just pop it in. There is nothing to assemble.
Since we don't want to post details of our mechanism design, we can show you what it looks like when installed. You can't see anything? That's the point. It's there, gotta look close. Final piece will be translucent with paint to match the maelstrom ramp color and texture so even if you could see it, it would fit right in.
https://pinballmods.co/maelstrom-hidden-switch-mod-jjp-potc
Stay tuned for our Maelstrom Wave mod which will allow you to hide the little tab on your ramp and is completely reversible. Also, your other option is to just dremel off that tab. I am happy to post of video of the easiest and safest way to do this. Either way no more ugly switch.
