On and off I've been working on a Flipper Fair that had many issues, and all is sorted
out but I'd like to know where's the Rollunder Switch? The Rollunder Switch is a switch
that's N.C. and completes the circuit to the Score Motor when the 50 Point Relay is made.
I went through a couple other Flipper Fairs, but never had an issue with a Rollunder
switch. It's not any of the Trough Switches. I jumped and bypassed the Rollunder
Switch, so the game does function properly, but I can't locate a mis-adjusted or dirty
Rollunder Switch which has to be the reason the 50 Point Relay doesn't give juice to
the Score Motor when it's energized. I can just solder a hot lead to one of the switches
on the 50 Point Relay and all should be fine, but I wouldn't mind knowing where a Roll-
under Switch suppose to be locate on the playfield. Maybe a switch I worked on dozens of
other times, but I don't remember. Any ideas?
