Say Guys, I have a quick question. On the bottom board between the Player Step Up and the 3/5 ball adjustment jack,
there's a set of switches. I'm thinking it's an Anti-Cheat Switch. My upper one is broken off. The Anti-Cheat Relay was
manually forced closed, so I'm guessing that switch should be normally closed, and also, could anyone tell me if the upper
switch in that set should have the common round weight at the end? Thanks for any responses. (T)
