So 5 years in the making (or really 12 since I inherited the machine), and I am finally starting to restore my 1962 Williams World Series. It has been 5 years since I found this SteveinTexas thread to inspire me to tackle this: https://pinside.com/pinball/forum/topic/williams-1962-world-series-pitch-bat-game-restore-%e2%80%93part-2#post-2459599
From that thread, you can see I have a number of issues with function, most of which appear to be down to gummed up steppers. I've been collecting parts, cleaners, waxes, knowledge and tools, and have finally started in earnest.
First effort was to remove the back assembly from the system, and check for stuck steppers. The first and most egregious of which was the replay unit. Through several pictures and a slow process, I got the assembly taken apart, cleaned, lubricated with some Teflon Super Lube, and reassembled. The improvement is massive, but I am not sure it is perfect yet. Take a look at the attached video and let me know what you think. I don't want to move the assembly back into the system to test as I have more steppers to clean up. But I figured I could get some good feedback while working on the others.
My thought is that the decrement should be working a bit more cleanly. Seems the spring should be a bit tighter on that, or maybe I need to wind/unwind the cog spring. On the other hand, it may just be that it is hard for me to readily simulate the click speed at which the decrement coil should fire.
