Quoted from Mopar:Like many, I'm suspecting the machine hasn't been played for quite some time.
You need to take your time and go through the Score Reels, Step Up Units, and
the Score Motor switches (clean and make sure they're adjusted properly) to start
things off. The one I just went through was pretty clean, but hadn't been played
for years. Score Reels wouldn't move freely. Step Ups were frozen, and Score Motor
switches needed a little filing and adjusting. The small Relays with the smaller switch
blades I use to clean them all, but because them having such close tollerance, I now
make sure they're switch stack screws are tight and they're blades are adjusted
properly, and only if needed I clean (lightly file) the switch blades during trouble
shooting..
thank you for the input. the machine was working well, then all of a sudden, no start game. it didnt sit for years or anything. I'm surprised its doing this, because I've heard if you keep playing em, they stay alive...
i've checked all fuses, and coil continuity, and the coin switch and everything looks good. all wires are solid. I guess next, I'll clean all the switches. there's a thousand of em, but thats em's.
