Removing Metal Stand offs from Playfield Plastics?
A quick easy way to remove them without damage.
All you need is a solder gun and a rag.
As you heat the metal post {from the inside} that are pressed into the plastic with full on heat.
In less than a minute it will become loose, check with a side to side motion pressing lightly on the post with the gun tip.
Once its loose lower the gun, grab a rag a quickly grip it to remove the Hot! post.
Throw the posts in the tumbler.
And now polish the plastics without interference from posts with your favorite plastic polish.
