Hi All,
I just purchased my first EM Pinball Machine a couple of days ago, and it just happens to be a Williams Expo. I'm as novice as it gets when it comes to this machine, and even though a good amount of it is working, it definitely needs some work. I reached out to Pin-It over the mail on here and he suggested that I hop onto this topic if I had any questions, etc... Any help in advance is most appreciated, my tools for pinball work are currently limited, though I'm planning on buying what I need as I go. I just ordered the Schematic and Manual for this particular machine and should have those in a few days, but have been trying to get some things working in the meantime. Definitely pardon my horrible knowledge of pinball terminology - I've always loved pinball, but have never been able to experience it to this extent outside of the occasional trip to the arcade when I was a kiddo - it's exciting getting my hands on this machine
Major problem areas I see at this point:
a. Start button was doing absolutely nothing, but is now resetting the game when the machine is first turned on. It also advances from 1 player to 2 player, and then does nothing after that point. I'm thinking it should keep rotating from 1 player to 2 player and back to 1 player if you keep pressing the start button, until you start playing possibly?
b. The switch at the 'drain' pardon me if that is the wrong term for it, basically where the ball falls to after going through the flippers, does not work at all. I'm not sure at this point what the issue is, all the wires in the box look to be in good shape, and without a schematic I'm at a loss to find where the wires coming off the switch are going once they hit the larger bundles. Without this switch working the outhole relay never fires, and I'd imagine the ball in play stuff will never get activated either, etc.. so I can't really verify that the actual game play is working at this point - ie: able to play the number of balls, getting the game over, etc... When I manually trigger the game over relay, the start button does work to reset the game now though, which is good.
c. When resetting the game in 2 player mode, the machine locks up constantly firing the score reset relay. I have included a video, and it appears that the 2 upper digits on the 2nd player score reset fine, whereas I thought it wasn't working at all, so there is an issue with it not being able to reset digits 1 and 2 to 0 on a reset, though the reels do work as when I play as the 2nd player the score increments as expected. I've fiddled around with the score reset relay just to make sure that all the switches were making contact and they appear to be. Possibly I need to pull out the first 2 digit reels for closer inspection - I'm really worried about doing anything like that for fear of damaging the wires.
d. On occasion during play all the lights on the playfield will go out, and some of the ones on the back glass will as well, though the game continues to work as expected, and the lights go on briefly when a bumper is hit, etc... The lights do go back on and stay on for a duration when the side switches are hit and the spinner operates. Rather odd, though this was happening after hitting the left flipper a few times, and I just recently used Pin-It's mod from this topic to close the switch contacts on the left flipper that fire the lock relay. I've fiddled with the lock relay when this happens and it appears to still be fully engaged, so not sure where the issue is, other than something with the voltage line for the lights..
All in all I'm feeling a bit better about working on the game, even after a couple of days. I recognized that the flippers were setup wrong and fixed that ( see attached photos if interested ). They were configured in such a way that the switches, when the flipper is held down, would never be activated. I was hoping fixing this would make things a bit quieter when the flippers were held down ( I believe I read somewhere that these switches put a lower voltage through the coil when holding the flipper buttons as less power is required versus when you are trying to hit a ball ).
Hopefully I can get the machine going 100% at some point, even as it is currently I let my 5 year old son have a go at playing the game and he was so excited, it made me feel awesome about the purchase.
Here is a video I uploaded of the machine, and the issues I'm having - might be easier to see what it is doing, if anyone can offer advice / help on how to fix the problems.
Thanks again for the helpful messages Pin-It, and thanks for letting me post to your topic about my machine.
Cheers,
Morgan
Post edited by morgan: uploaded same wrong flipper photos
