When I replace the fuse and turn the machine on, the coil for the locked balls fires and stays on. That much I do know. I'm not sure about any others. I've checked it to see if it's bound up but it does move freely with power off. I've also checked the other coils and they seem to move freely just fine. I can't really see the lugs and wires for the lock lane coil since it is covered up. So I'm guessing I should take the black plastic cover off to get to it so I can visually inspect it. Is that true? I did inspect all three of the switches that are in the lock lane and I don't see anything visually concerning (loose wire, bad joint, etc.,).
I do have a DMM which helped me find the bad fuse. I'm not entirely sure on how to check a transistor or coil with DMM but maybe you can point me somewhere I can learn.
On power up I also hear the AC relay clicking on and off over and over.
