Chiming in late this probably is obvious by now. The green wire is typically your safety ground you can loss it and the pin will work. So why have this? They changed the code and required that manufacturer use safety/cabinet ground. A good system has its components if conductive grounded.Voltage takes the path of least resistance any leakage or coin door grounded you feel a tickle well that's amperage flowing through your body you are part of the circuit. Never delete the 3rd prong on the cord, just change the outlet. If you have 3 wires feeding your outlet make sure it is grounded to outlet and box if metal. I also use a surge protector and use it like a switch to kill power instead of unplugging.
