Well, here is what’s going on so far on my Twilight Zone.
Switch 84 was not working which is the middle lock. No errors, and everything was fine in the switch tests.
I kept testing the optos in the switch tests, I was able to get an error in the switch edge test but only once but couldn’t reproduce it. I assumed it was the optos so I bought some new ones and installed them tonight.
Nothing, everything is the same, if you put a ball in the lock , the upper lock registers and the lower locks registers but the middle lock (switch #84) nothing happens. I fooled around with all the connections and they looked pretty good. No errors and the switch shows that is it closed like it should, just like #85 (upper) but as soon as you turn on the machine, the kicker fires several times.
I then replaced the opto board with new 10 switch opto board from Great Lakes. The kicker has stopped but switch #84 is still not working and now the gumball enter switch (#87) reports an error. There are two blinking red lights on the new opto board representing the 84 and 87 transmitter.
I then took the optos out and put them right next to each other . . . . nothing. In order to get the middle lock transmitter out, you have to take the upper one out also. That one (#85) was working correctly and showed that it was now open like it should one since the beam was not hitting the receiver opto. But on #84, it does nothing whether they are facing each other or not, just still indicates that is closed. I double checked that they are wired correctly and they are. I would think that the opto is bad but these are new ones installed and the old ones I took out did the same thing?
Any ideas?
