A while ago, I've started my project to convert all my lamps in the playfield to LEDs. My 1st phase, the general illumination, is completed with no issues. My 2nd phase has started and ran into a snag. I started to notice that after I installed the orange and yellow effin-bright LEDs, they started to dim and change color. Argh! Why is this happening?!
As I am changing the feature lights to LEDs, I noticed something unusual from the orange and yellow LEDs. When left on for a while, the oranges start to dim and turn almost red. The yellows will dim, too, and turn to orange. Wait a min. That's not supposed to happen unless the voltage to the feature lights are too high! Going back to the schematics I discovered that Bally/Midway invented a scheme to use a double-phase circuit that will light one group of lights while the AC voltage reaches the positive peak on one lead and then light a group of 2nd set of lights on a second lead when reversed. So, half of them operate 30 times a second not 60 like the general illumination does. They decided to step up the voltage to almost 11 volts AC, instead of 6.3 volts, to make up the lost power to the filament bulbs. Clever, huh? Not so for LEDs! (Bally/Midway harnessed the AC voltage to turn on their feature lights, not the lamp matrix scheme Williams used in their machines.) Before I go further, I will need to get some kind of current limiting power without building a complex circuit for 2 phases. I found a couple of rheostats that will handle the power, but they aren't cheap! (Rheostats are high-power potentiometers that can handle a lot of power at a constant length of time.) Now it makes me wonder how I will handle the brights, or flashers, they use. They, too, use a double-phase circuit to flash them at 24 volts AC.
Do you have a different solution? Is there such a thing like a solid-state AC dimmer, the one that does true voltage limiting and not the circuit that cuts off at a certain time of a sine wave? Let me know in your reply.
The LEDs I am purchasing and installing are the A-Blaze premium ghost-buster LEDs.
