I posted this on my local Florida Forum. I figured I'd cut and paste it here as I am welcoming a discussion in my current frustration.
Sorry so long.
I have been trying so hard to reach this seemingly mythical mode. To my knowledge nobody has ever reached it legitimately. The best I have read about is 4 blinking lights (Bowen) and I am sure others have done it as well. I have achieved 4 on my game (set to factory) and it was a miraculous and rare feat.
Recently I was playing Iron Man on location and it is set up easier than mine at home in that the outlanes are all the way closed where mine are open one from the top. Now immediately, I can anticipate the “oh the game is too easy that way.” That was my thought too, and I figured I could go full throttle toward Do or Die Multiball. But I keep hitting the 4 blinking light roadblock, just more often now, with the 5th (usually Drones) just out of reach. It finally dawned on me that I need to have a near perfect game to do this.
As a quick refresher, my understanding is for DoDMB, you must earn all the blinking lights:
Complete 3 sets of Iron Man targets
Earn the SJP on War Machine
Earn the SJP on Iron Monger
Earn the SJP on Whiplash
Complete 4 sets of Drones (light WM MB 4 times basically)
Note: (I actually thought it was 3 sets, and when I earned the 3rd set recently, I was rudely awakened)
This does not need to be on one ball which makes it different from regular Do or Die.
Let’s look at the optimal set-up on how to reach it:
Ball one goals, not in any order:
Play one round of Iron Man, earn the SJP for Iron Monger, get the first round of Drones, light War Machine, start Whiplash (I like to use War Machine and Whiplash together), earn the SJP for War Machine and Whiplash. (Way easier said than done BTW)
By this time you would have earned 4 Marks for those tasks (Drones will not light a Mark and keep in mind you do not need a SJP to earn a Mark). You have also probably completed a set of SHIELD lanes, which lights a Mark. If you went for Bogey ramps that would have also earned a Mark.
If you did the above and avoided Bogey you would be at 5 Marks. Now you have to be careful. You are close to Jericho being lit. It is either going to light from the next Iron Man target set or if you play Bogey. So here, I would AVOID Bogey and just go for the Iron Man targets to be 2/3 of the way to the Iron Man blinking light. Once you complete that 2nd set (again assuming you did everything else I described), Jericho will be lit.
Note that if you start Jericho, you have to win it to keep on playing that ball and of course you make ZERO progress toward any other goal. If you fail, you reset the Marks and start again and even worse are now on Ball 2.
Finishing Jericho is a bear, but it can be done. Whether you finish it or not, after you are done the Marks reset. Most likely, you will not finish it before draining. Not being pessimistic, just that is the likely outcome since it takes so many shots to finish it.
But let’s assume you are on a roll, the ball does not drain and now have 4 blinking lights on Ball one and Jericho is lit or you played it and won it (even better!) You have to work on 3 more sets of Drones.
This becomes quite the chore since each round you have fewer Drones available to hit. If you have avoided Jericho, it is still lit and 2 of the available Drone targets you need are right near the center shot. They are also the risky ones to hit. You could try for the War Machine target to add an available Drone target (Jarvis says “Drone added”).
Of course in our perfect world you have not drained yet.
Despite our daydreaming here, chances are you are going to stumble into Jericho eventually. Once it is over you are back to most things earning Marks (a set of SHIELD lanes, Iron Man targets, Iron Monger multiball, War Machine and Whiplash, Bogey) and climbing dangerously close to Jericho AGAIN. So I would still suggest, stay away from Bogey.
In short, Jericho is NOT your friend if you are trying for DoDMB. If you are on Ball 3 Jericho really becomes a “do or die situation” since you are locked in.
In summary, I feel the hardest thing to do is get that 4th set of Drones. Since 50% of the drone targets are located near the Jericho shot, your best bet for getting the Drones done with less worry is to go for them first, light WM, go for the next set, play WM etc. Or else just play Jericho as fast as possible-Ball 2 at the latest.
I would say 95% of games played by ANYONE are not going to result in a perfect first ball scenario. That is, the ball will drain along the way and Jericho will probably be lit on ball 2 or ball 3. If Jericho is achieved on Ball 3, the chances of reaching DoDMB are extremely slim since winning Jericho is rare.
So your best chance for DoDMB is reaching Jericho on Ball 1 and just getting it over with by winning it or draining and moving on. Then be careful as you get closer to the 2nd Jericho.
Misc. Tips I find useful:
If the game has a ball saver, use the ball save time to work toward the tricky side-to-side Iron Man targets. You can accomplish a lot in 5 seconds
Learn to backhand WM to add Drones
Avoid playing Iron Monger after you earn the SJP. It interferes with Drone targets and you cannot work toward Whiplash
I hope to reach DoDMB eventually. Unfortunately my best hope right now is on a game not set purely to factory.
If anyone has reached DoDMB, I’d love to hear about it.
