Fixed! IJ upper playfield GI out
Started 1 year ago by ab3 in forum Technical help.
Forum » Technical help » Topic
  • 225 karma points were scored in this topic
Tags
No tags yet.
    I was playing my Williams IJ tonight, and I noticed the upper GI lights went out while playing. I shot up the right ramp, and the lights went back on. A minute later I hit the drop targets and the lights went back out, and didn't come back on.
    Looking at the manual, the upper lights are all connected with the white brown wire. I checked this fuse in the back box, it looked good but I replaced it anyways, and the lights are still out.
    There are about ten lights on this circuit. The three under the diverters below the NDY light up extremely dimly, and the rest are out completely. When I touch the white brown wires underneath the playfield, they feel very hot to the touch. I checked but didn't find any obvious loose wires, and I tried to reseat what i thought would be the appropriate connectors.
    I'm not very experienced with this, but I'm desperate to learn. I'd greatly appreciate any advice/suggestions. Thanks for your time, any insights, and patience!
    Post edited by ab3 : Problem solved
    Have you checked the connectors to the power driver board? Might find some crispy molex!
    Thanks,
    I looked at J121 on the power driver board, but no sign of crispiness. Any other thoughts?
    Don't know if it's important, but all of the lights on this circuit are LEDs. Anything unique about LEDs that might have caused this?
    No.
    Since it sounds like it is possibly working or not working during times of vibration I would think wires or connectors loose. Maybe a cold solder on that strand. Since J121 is fine. Have you removed or checked all connectors on the bottom side of the upper playfield? Had diode bend up and cause weird issues before also.(the one close to the mode start hole)
    Did you see problem soon after installing LEDs? If so check the sockets for anything out of the ordinary. Do you remember having trouble with a particular socket in that strand?
    That was exactly the case for my lower playfield GI on Indy recently!
    The LEDs were put in about a week ago, and no problems noticed until today. I tried reseating all of the connectors underneath. What I can't understand is why are the three lights under NDY diverters lit very dimly (clearly they're getting some power), and why does the white brown wire underneath feel so warm. Thanks again for any other ideas to try.
    Edit: I had to reseat and move the wires around in the LEDs in the pop bumper several times until they would light, but they have be working fine for a week since.
    Post edited by ab3 : Maybe related
    Well it could be a partial short to gnd, a poor solder connection that has some resistance to it,
    A flaky lamp socket, etc.
    The wire getting warm would indicate that there is excessive current draw through that wire.
    Have you measured the Voltage at one of those sockets? Can you easily remove all the bulbs in that circuit?
    I can remove all of the bulbs in the circuit relatively easily from under the playfield, except for the pop bumpers from above. Do you recommend I remove all of them? Thanks.
    I would check the bulbs. I had an 89 flasher last week come apart from its base and caused all sorts of havoc.
    Solved-
    I decided to start taking the plastics off so I could access the upper playfield GI from above. It turns out the raise jackpot when flashing plastic had managed to push the wires from the left ramp opto slightly out of position (making contact with something it shouldn't). When I readjusted them, all the upper GI lights came back on!
    I'd be happy to be educated by anyone here as to why the left ramp opto wires could cause the upper GI lights to go out. Thanks for everyone's help and time.
    Glad to see you fixed the problem. Were the opto wires insulation cut into?
    I'll look at the schematic and try and see why this happened but it looks like the opto wires were shorted to the GI circuitry causing your problem.
    The opto wires were not cut into (this was the part of the opto on the right side of the left ramp by the way). The exposed part of the lead going to one side of the opto was long enough, such that it managed to touch one small solder point beneath it that it shouldn't have been touching.
    I'd be grateful if you were able to tell me how this shorted the upper GI, thanks.
