Greetings,
I’ve already posted this on RGP but we haven’t had much luck pinpointing the issue. So I thought I’d expand over to here in hopes another set of eyes will be able to help out.
Issue:
Black Knight (System 7) Blanking Circuit Signal will not go between the 4v-5v requirement to play. It actually measures just a little above 3v. If I jumper the blanking test point with 5v, the game plays just fine.
Parts Replaced on MPU:
IC23 (and also put in a socket since it did not have one)
IC7 (and also put in a socket since it did not have one)
Q1
Q5
C84
C31
C27
Voltage Measurements:
Test Bench Power Supply = 4.91v and 12.02v
TP1 = 12.02v
TP2 = 3.89v
TP3 = 72.5mv
TP4 = 3.4v
TP5 = 4.64v
TP6 = 2.37v
TP7 = 4.69v
TP8 = 4.73v
TP9 = 4.81v
Header Pin 37 = 3.4v
1J3 Pin4 = 3.4v
IC23 Pin 8 = 4.84
Continuity Testing from IC23:
(All test near zero)
Pin 1 to ground test point (TP10)
Pin 2 to the junction of R21, R22 and Q21 base
Pin 3 to
-TP4
Pin 4 to
-IC36 Pin 34
-R29
-R30
-Q2
-TP8
Pin 5 to
-C17
Pin 6 to
-C31
-R23
Pin 7 to
-Pin 3 of IC23
-TP4
-Header pin 37
Pin 8 to
-C63
Any other suggestions what to test / check?
Thanks much!
