Well....it looks like we were wrong.... While playing the game today I indeed noticed that the left orbit opto was not working/scoring. Well crap. So, I start taking a look around under the playfield and notice one of the leads on one of the resistors on the opto board is broken. Aha! I say. So, quickly repaired the broken lead.......still doesn't work. We begin taking the stadium section off AGAIN to get to the hardest to reach opto on the entire game (of course). My dad takes it and resolders optos just in case they were put in backwords. He brings it back in and it works! However.......all of the wacko scoring issues resume, with it scoring billions every other pass of the opto. Also, the coil that raises the shooter lane is kicking on at ball start and the ball kicker is again kicking as soon as you press the start button. But hold on, there is more! Now the coil that releases the ball into the shooter lane is no longer working. UGHHH!
So, we try all sorts of things INCLUDING unhooking the problematic opto on the left orbit and it is still the same. The game is going kind of wacky upon starting a game and that coil isn't kicking the ball out. We check the fuse on that coil and it is fine. We go into the coil test and the coil will work in the coil test.....?!>!>
As you can tell I am getting pretty frustrated with this machine. It is such a shame as my dad has made this thing BEAUTIFUL. Pity it worked fine before the teardown and now it is being a *$#&$&. We hooked everything else back up to just see if there was a problem with something being unhooked but it still acting strange like mentioned above. We ran a switch test and coil test and ALL coils and switches work in the test.......... What could we have done? Is it possible the rom is corrupted or something? Also, the driver boards, opto boards and mpu have been switched with working ones from his Stargate and the same problems persist.
Quoted from viperrwk:First thing I would do is run the individual lamp test and as you test each lamp look for any other lamp that's ghosting on. This may be difficult to do if you have installed no-ghost LEDs but there may be enough to show you where the short might be.
We will have to try this it seems. Could a bad LED cause the symptoms we are seeing? I would hate to replace each LED, one at a time and testing to see if the game works.
