thanks for the hint, I was also trying to figure out why the vengeance is leaning to the left and it really seems to be the cable!
but I am not sure how you actually modified it. maybe I can't figure it out due to the angle of the picture.
When I look at your attached picture, it seems that the cable is fixed with a second holder on the second screw, but if I would attach the cable there, the vengeance would not be able to move forward/down enough as the cable needs room to move there. or does the cable make a curve now between those two points where you attached it? I don't really get it.. would be nice to see another pic from a different angle if possible.
btw, for anyone trying to mod the vengeance ship: watch out, don't pull the ship too low by hand while adjusting the cable! there is a point where the coil slips past the "latch/release" mechanism and remains locked in "defeated/down" position forever and does not return to normal state anymore (even via diag menu).
I had to remove the black cover plate to find out what exactly happened. it's also possible to fix this issue without opening the black cover, but it's tricky. it would be self-explanatory if you see it, unfortunately I forgot to take a pic after opening, so it's not that easy for me to describe the restore procedure in proper english in the coil diag menu there is something like "vengeance latch", but it only sends a very short pulse to the coil, not long enough to slide the vengeance coil mechanism back to normal position. so you have to try to send several pulses to the coil while trying to push/pull the vengeance past the locked latch. after several attempts everything was back to normal.
