Hey all this is not one of those panic posts I know machines are meant to be played and that there will be some wear. That said, I notice after about three weeks the pinballs in the machine looked very torn up for the amount of play put in on them. I noticed some small scratching on the playfield which was my reason for checking the pinballs. There appeared to be some obvious reasons for why this was happening.
One was the shoot button has the metal kicker shoot the ball way more often than on other pins. So I put 2 small felt tape strips over the spots that the kicker contacts the pinballs. This did not affect how hard the ball was shot out at all so that is good. The second was where the ball kicks out on the field from the shooter lane there was a vertical metal strip that is usually much closer to the metal that is flat on the shooter lane (at the end of it). Resulting in the ball getting chewed up much more in that spot with little dents and chips off of it. So I put a felt tape strip across it hanging over just a bit so when the ball goes over it the tape will prevent metal on metal contact. Changed the pinballs out and I think the extra abuse on the pinballs should be reduced significantly. Just thought I would share that with other owners in case they noticed the same thing.
