(Topic ID: 72075)
Spirit of 76 part help
By slawnski
10 years ago
  • 23 posts
  • 10 Pinsiders participating
  • Latest reply 10 years ago by Cruzin1a
#1 10 years ago
I just started work on a recently aquired Spirit of 76 - The curved metal shield behindthe kickout hole in the center has 2 broken tabs and I'd like to replace the piece if I can- anybody have the name of this piece? or the Gottlieb number? I can always call Steve but I'd like to have the right name and part number if at all possible- Thanks!
#2 10 years ago
I looked through the '76 and '78 Gottlieb parts catalog, and that part doesn't seem to be shown. The '78 parts catalog has the So76 and Pioneer playfield layout and parts, but it's not called out on that either.
So... might just have to email a picture and description. Probably a long shot that he'd have it though, since it may be a game-specific part.
#3 10 years ago
Crap! Thanks Dirtflipper! Worst case- I can see about repairing the one that's in there now- I'll take a picture of the piece itself tonight and post it-
#4 10 years ago
This is what I would do if I couldn't find a replacement.
I'd get the smallest machine screw, nut and star washer from my local hardware store. Then I'd drill an appropriate sized hole through the curved metal guide and the broken off L bracket, drilling the hole lower than where the ball will roll.
Then I'd grind down the height of the screw head as flat as possible to keep it a good fastener. Then I'd grind down the diameter of the screw head so it's just a bit bigger than the drilled hole and put it together with the lock washer under the nut.
Something like this:
#5 10 years ago
Do you still have the tabs? If you have access to a metal shop you may be able to get the tabs brazed back on. Back in the day I used to use a product called Metal Set A-4 Epoxy. It's super strong and you can try and use it to affix some brackets as Steve suggested above minus the screw. Obviously the mechanical screw attachment would be stronger, maybe. You could also use countersunk rivets to attach the new brackets, they would be much less visible than a screw head.
#6 10 years ago
Thanks guys- I do have the tabs - maybe I'll try one of each method ( I have two broken tabs- the center tab is still good- we can contrast and compare the results-
#7 10 years ago
The smallest machine head screws are a pain in the ass to find. I went to 3 different places to find them but they are this size. 6X32 @ 1/4th an inch (flat head). You will NOT find them at Home Depot or Lowes. I had to get them at a place called Elliot's Hardware. These are the same screws you use to screw down a ball return gate or a rebound bracket to the upper apron.
#8 10 years ago
Both mine were broken as well and I could not find a replacement but it was a simple fix, Just Solder the 2 tabs back onto the metal horseshoe and use flux and a solder gun that generates a lot of heat. I have played many games on mine and it still holding strong.
Here is a powerful high heat solder gun.
http://www.amazon.com/Weller-D650-Industrial-Soldering-Gun/dp/B000JEGEC0/ref=sr_1_8
Ken
#9 10 years ago
Check with Steve Young at PBR.
I've bought this part from him in the past. Not sure if he has it in stock still.
Mike O.
Team-EM
#10 10 years ago
Are these similar to them? I had these made some time ago when I needed more. When I noticed they seem to break a lot, I asked Cliffy to make them with a little thicker material. Looking in my parts manuals, all I could find that may be the part is Part # A-20362 flat rail support clip or maybe A-20365P support post. I'm not sure this is what you need since there is no pic.
Steve
#11 10 years ago
Sorry I didn't get a pic on here yet- I'l get that up here tonight- Steve- the clips might work if I can't solder the originals back together- I assume the top hoop goes over the top of the guard? going to try solder first- just puled my parts out of the tumbler last night - I'l post a picture later today
#12 10 years ago
Solder might discolor your metal? May try a pop rivet. Or like Mike-O says, just buy one.
#13 10 years ago
Quoted from newmantjn:
Hey Todd, Mine came out bright and shiny once I cleaned off the flux residue then polished it. Even if you had some slight discoloration those 3 tabs are pretty much hidden from view because of the Posts and the Plastic.
Ken
#14 10 years ago
The strongest epoxy I've worked with is JB weld. I buy the stuff that sets in 5 minutes. The stuff is so strong and I even used it to fasten rear shock absorbers on a '65 Chevrolet way back when. (Well sorta)
#15 10 years ago
#16 10 years ago
Used acid sore silver bearing solder and a micro-torchimage-648.jpgimage-648.jpgimage-597.jpgimage-597.jpgimage.jpgimage.jpg. Here are the results the close ups are after solder- I buffed the part on the buffing wheels for a bit and I like the result. We'll see how it holds up.
#17 10 years ago
Noticed one tab was off a bit and hit it again with the heat and got it in the right spot.
#18 10 years ago
Quoted from slawnski:
Looks like a nice job and should hold up. My exact 2 tabs were broken in the same place as yours.
Ken
#19 10 years ago
EM- was the plastic above this feature damaged as well ? Mine is broken in three places. I'm thinking the wobbly guard lead to the ball bashing the plastic into pieces.
#20 10 years ago
I bought an all new Plastic Set from PBR for mine. If you want to save your next middle plastic here is what someone did to mine after the fact. They got a piece of plexiglass the same thickness as the original and cut it to the same exact shape as the original plastic, then installed that under the original to protect it from the ball poping up and cracking it again, Brilliant!. The acorn nut still has room to attach to the post as well. You will never break that plastic piece again by doing this.
Ken
#21 10 years ago
Turned out GREAT!!!
Congrats. IMO, there is more skill required in a good repair than just replacing parts. I usually opt for part replacement though....soooooo.....yep.
#22 10 years ago
Great job on the repair!
The plastic graphic above my center hole was also broken. I tried gluing a metal stint across the crack but it soon broke again. Investigating, a full force flipper shot straight across the hole's center causes the ball to strike the further upper edge of the hole. The ball hitting the far edge causes it to jump up and strike the plastic. No wonder so many of these are broken.
My absolute fix was to use a spare piece of thin sheet metal about 20 gauge. I used the original plastic as a template and cut the metal to be the same shape and size of the graphic. I drilled 4 post holes in the metal and painted it. I put the metal over the 4 posts, then the plastic graphic then the 4 post nuts. Now the ball occasionally smacks the steel not the plastic.
I could have painted the steel something other than brown but this is what I have:
#23 10 years ago
Quoted from SteveFury:
I've used it to repair a hole in an exhaust manifold for an old boat I had. It worked great lol.
$ 99.00
RGP Models
Gainesville, GA
1,700 (OBO)
Sullivan, WI
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/spirit-of-76-part-help and we tried optimising it for printing. Some page elements may have been deliberately hidden.
