(Topic ID: 37712)
Scared Stiff Lamp Backbox Board Artwork - Replacement - Who wants one?
By Muppet_Man
11 years ago
  • 17 posts
  • 6 Pinsiders participating
  • Latest reply 11 years ago by kmoore88
#1 11 years ago
My Scared Stiff was in great condition when I bought it, except for the Translites lamp backbox board artwork (part number is 31-2587.2). It looked like someone had left the key in one time and then tried to open the board to get to the electronics behind. Result - smashed at the top (see photo). I've tied for over a year to get one, and it's been next to impossible. The only one I saw went for £300.00 on E-Bay, and I was too late for it anyway. I wish I'd have seen it beforehand, as quite frankly, to put the game back to perfect I would have bid.
However, you can't go on about things you could have had. So, it's got to the stage when to get my pin back to how it should be, I've had to bite the bullet.
This has involved about two months of work and a whole heap of cash, but eventually a new one has been made. In fact not a new one, but a new ten, because this was the minimum run they would do for me because of the setup costs of the machine.
I've included here a photo of the prototype they did. This one has a glossy front, which I didn't want, so they are going to make the next ones matt like the original. However, it still look damn good, and a whole heap better than what I had.
Now, these are not original, so please don't say that you'd only want NOS. Because as far as I know, there just are not any left, but these are pretty close, and given the option of looking at a genuine busted version, and a non genuine perfect version, I know which way I'm going.
In order to get some of the large sum I've shelled out back, I'm going to sell the other eight (I'm keeping the glossy one as a poster, plus one to repair mine and another as a spare in case I'm an idiot at some point in the future and break one).
I'm waiting for the final price off of the people who have done it for me, and once I've had it, I'll have an idea how much they should be.
But anyone who is interested, then by all means let me know. PM or just reply here, no problems with either.
Of course it may be that I'm the only one with a broken one, in which case I've just carried out the Worlds most expensive pinball repair!!
Cheers chaps.
#2 11 years ago
Here's the photo's, old and new.
#4 11 years ago
I've tried to take a photo here of it with torches behind, just so you can see the figures lighting up, but because it's not mounted on the backboard, the lights washing through and making everything look washed out. I'll post one as soon as I have a finished one mounted.
Cheers
#5 11 years ago
Man, that's nice! I was looking hard for one of these for a while and managed to find a NOS one believe it or not. Mine was cracked in the same area.
I think mine got hot and brittle from the spinner board behind it. It looked like the spinner board was not spaced back far enough, allowing a heat sink at the top of the board to press against the rear of this art panel. I think it heated up the panel, made it brittle, and it just broke. There seems to actually be some melted plastic from this art panel on the heat sink.
So just a word of warning when you reassemble this, be sure nothing from the spinner board is contacting the rear of this art panel, just to be safe.
#6 11 years ago
Excellent note Rum-Z. I've just been a checked the layout, and I can see the transistor that gets hot. Although this would take a long time to effect the new board, I may look at including a small steel mod to help dissipate the heat away.
Much appreciated.
MM
#7 11 years ago
I may be interested, depending on cost and how it looks lit up. I've got 2 SS backbox inserts, both damaged. While they do shatter in that area, they also crack in areas that are just touching the wood board, no heat behind them, which is not as easily noticeable, but it does happen!
#8 11 years ago
Just to make everyone aware. This is the artwork, and not the whole board. So you will need to peel off your old one to apply the new one. This took me about ten minutes with a pallete knife.
The good news for this is if you live overseas, it shouldn't be a problem posting it, as it will roll up into a tube.
Thanks for the PM's guys.
Super exclusive ad from the Pinside Marketplace!
#9 11 years ago
Quoted from johnwartjr:
Thanks for the note JW. I must admit I thought I might have been the only one, but by the PM's I've had, it would seem I'm not alone and as you say, they seem to break in other areas also.
Ta
#10 11 years ago
I need one of these as well. Mine is cracked. I keep hoping they repo them someday.
#11 11 years ago
Quoted from Rum-Z:
It looks to me as if a simple bit of heat resistant tape should work fine in front of that transistor. I'll make sure to use some on the back in the relevant position.
#12 11 years ago
Message got thanks ABT12
#13 11 years ago
Just so you guys know, I got the obligatory "Your infringing copyright" e-mail.
They of course have every right to send this, and it was a polite enough mail and of course I wouldn't want to upset anyone. So no harm done, and I pointed out eight items sold for no profit is hardly going to effect them.
I've offered them my artwork and stuff if they want it, so hopefully the World of Pinball will continue to move (drag kicking and screaming) on so we all get the bits we want to keep our pins in good nick.
If producing something yourself leads to getting a factory original reproduced, that wouldn't be such a bad thing.
Now what do we need next......? Suggestions on a post card - as the saying used to go
#14 11 years ago
Well heck, if they would just produce that damn things, I would be more than happy to purchase one from them. It sounds like many of us need this part. I was just happy that someone finally offered it. I guess they could take you to court for the 25 bucks profit your going to make in the end. Seems counterintuitive to me.
#15 11 years ago
Make sure you get a fat check for your efforts if they take your art. Guarantee THEY won't be selling "at cost"....
#16 11 years ago
Cheers chaps, I'm imagining that they would have access to all of the original artwork, so for them, it probably wouldn't be anywhere near the problem that I've had. I did ask them just out of interest, but didn't get a reply.
Onwards and upwards.
2 months later
#17 11 years ago
Whatever happened with this?
$ 85.00
$ 89.99
$ 27.95
8,995 (OBO)
Weeki Wachee, FL
8,900
Ontario, CA
$ 125.00
£ 49.00
PinballToys
7,800
Hermosa Beach, CA
£ 49.00
£ 38.00
YouBentMyWookie
$ 159.00
Sparky Pinball
$ 49.00
$ 249.00
Red Oak, TX
£ 31.00
PinballToys
$ 17.50
Playfield - Plastics
$ 89.99
£ 79.00
PinballToys
$ 62.00
$ 27.99
Lee's Parts
Filament Printing
This page was printed from https://pinside.com/pinball/forum/topic/scared-stiff-lamp-backbox-board-artwork-replacement-who-wants-one and we tried optimising it for printing. Some page elements may have been deliberately hidden.
