(Topic ID: 39400)
R&B Rocky and Bullwinkle - mod to reduce power at the Lion backbox coil
By RussMyers
11 years ago
  • 13 posts
  • 5 Pinsiders participating
  • Latest reply 1 year ago by MWM82
  • Topic is favorited by 18 Pinsiders
#1 11 years ago
OK,
My experience with working on my own R&B pinball backbox (and reading RGP posts about it), the conclusion that I (and others) have come to the conclusion that the lion backbox hat trick coil is probably overpowered for the job. All of the coils are the same, but the Rocky and Rhino coils get 32v and the Lion coil gets 50v. This is most likely why the Lion plastics are beat to crap and there is often a notch in the lion metal lever arm where it smashes into the backbox assembly frame.
I removed all of the lever arms, cleaned the pivot points with iso alcohol of any old grease and dirt and lubed very sparingly with teflon gel at the metal-to-metal pivots. I also cleaned the plungers and the coil sleeves.
With everything moving freely and several new parts, at the factory wiring the lion plastic and lever arm were just smashing upwards too hard, IMO.
I de-soldered the 50v power wire from the lion coil, heat-shrunk over the exposed end and tucked it away with a zip tie. I then cut a new piece of wire, tinned both ends and daisy chained the lion coil from the 32v power wire that already was chained between the Rocky and Rhino coils. I used the end lug because it only had one wire on it already. It was very easy to do.
RussMyers
#2 11 years ago
Thank you, Russ. I'll do the same to mine.
#3 11 years ago
Be sure to test function before you button it back up, but on mine there was still PLENTY of power to get the job done.
The Lion plastic still goes fully up and down smoothly, no hesitation or binding or anything.
RM
#4 11 years ago
Quoted from RussMyers:
RM
Did the mod this morning. Worked excellent, and no slamming like before.
Thanks again.
#5 11 years ago
Boo yah.
RM
#6 11 years ago
I also recommend upgrading the padding under the hat trick plastics.
The foam weather stripping is just not good enough. The edges of the plastics come down like guillotines and chop it up. This is also a factor in the plastics breaking, IMO.
I used adhesive-backed felt, cut to cover the entire metal plate the plastics rest and land on.
Like this:
http://www.homedepot.com/h_d1/N-5yc1v/R-100198682/h_d2/ProductDisplay?catalogId=10053&langId=-1&keyword=self-adhesive+felt&storeId=10051#.URehzvLjKf0
RussMyers
#7 11 years ago
Like this:
RussMyers
Could you post a pic?
#8 11 years ago
Different question but at what point during game play is the ramp diverted supposed to flip over. Not the diverted for the hatrick - one on the actual ramp
#9 11 years ago
How's this?
RM
#10 11 years ago
Quoted from Hobbypinball:
I believe it always opens when you hit the right ramp so that the ball returns to the right flipper. I can't recall it ever not opening so that a shot to the right ramp returns to the left flipper.
#11 11 years ago
I believe the Spin n Win ramp diverter diverts the ball back to the Right Flipper always, except when Spin N Win is active, so you can keep hitting the right ramp from the left flipper.
From the IPDB ruleset:
"Spin-n-Win
The first frame shows Bullwinkle on the left side of the screen and a steam roller on the right side. This round lasts for 20 seconds as well. The goal is to keep hitting the right ramp. The Pie will keep changing, and the color that is lit at the time you hit the switch is the value you get (it's either 5M, 15M, 10M, or 20M, in that order). The ramp diverter will NOT divert the ball this round, enabling you to keep shooting the right ramp over and over. Hitting it resets the timer to 4 seconds for unlimited shots. The total is displayed here too, but it is awarded as you go. This round can actually be pretty lucrative if you can keep hitting the ramp, esp. with an average value of 12.5M per ramp shot!"
RM
#12 11 years ago
Perfect! Thanks Russ.
9 years later
#13 1 year ago
Did this tonight. Thank you for saving my new plastics and tracks from getting smashed.
$ 18.00
Playfield - Plastics
$ 49.95
Mitchell Lighting
$ 69.99
Daddio's 3D Printed Mods
$ 14.95
$ 12.00
Filament Printing
$ 29.50
$ 18.00
$ 27.95
YouBentMyWookie
Hardware
Filament Printing
$ 32.00
This page was printed from https://pinside.com/pinball/forum/topic/rb-rocky-and-bullwinkle-mod-to-reduce-power-at-the-lion-backbox-coil and we tried optimising it for printing. Some page elements may have been deliberately hidden.
