Question about SoF multiball: Figured it out.
Started 12 months ago by EvilJack in forum All Pinball.
Forum » All Pinball » Topic
  • Started 12 months ago by EvilJack
  • Latest reply from EvilJack
  • 255 karma points were scored in this topic
Tags
No tags yet.
    12 months ago | # !! © |
    So today while playing I started a multi-ball game with only two balls. I thought there was only a three ball multi. Is this supposed to happen? And under what cercimstances does it happen?
    Also I had another interesting thing happen. I knocked down all the targets on the mini-playfield once for 2x multiplyer. However the ball left the playfield and hit the titan spinner just as the light was changing from 1x to 2x. This caused the light to go directly to 4x. Is that how it works or is that a fluke?
    EvilJack said:
    So today while playing I started a multi-ball game with only two balls. I thought there was only a three ball multi. Is this supposed to happen? And under what circumstances does it happen?
    This happened on my SoF as well, with both the old and newer software installed. I could never figure out what caused it, but it happened every once in a while. I'm pretty sure this is the case with all SoFs.
    Sounds like a defective machine. Sell it to me
    I had the same thing with mine with both old and new roms. I could never figure it out either but I thought I read somewhere it was a common to all sofs.
    Same here, happens every once in awhile. Im gonna pay better attention next time and see what triggered it.
    Mine did it to, I even read why it happens, but cant remember.
    Check rgp, pretty sure I read about it there!
    The first time it happened was when I first got the pin. Wanted to show my friend the multi-ball music. Rolled two up the ramp right away and it kicked both out. However it did it this last time with more time between the balls.
    I do not recall getting two ball multi on mine, it has been a while tho, Miss my SoF, great game
    I think I have the answer.
    I was playing my brother's and I've had this happen. It looks like when the ball ejects out of it's lock spot, it will sometimes not go around the horseshoe and land back on the switch again, causing multiball.
    I just took the glass off and verified.
    When 1 ball is locked, the ball launch diverts to the ball lock, and kicks out the first locked ball for play. If that ball does NOT kick out all the way, they both drop in and start 2 ball multi.
    When 1 ball is locked, the ball launch diverts to the ball lock, and kicks out the first locked ball for play. If that ball does kick out all the way, they both drop in and start 2 ball multi.
    Ok, but did you get a change in the music? I will see if I can force it again, but I believe it starts with the "LION MAN" shout out and then the multi-ball music starts.
    This has happened to me a lot of times as well. Always seemed random to me. I just assumed there was some intricacy to the rules I wasn't picking up on. It does start the multiball music though.
    EvilJack said:
    RawleyD said:I just took the glass off and verified.
    Yeah, it starts the music. It's multiball as usual. Try it with the glass off and see.
    It definitely has something to do with that diverter. I don't think there is supposed to be a two-ball multiball, but the software is obviously designed to compensate.
    11 months ago | # !! © |
    Ok so I figured out what causes 2 ball multiball. Its basically just a mistake. The programing for the multiball is designed to work one way. Power one is when the ball rests against the lever in the trough. Power two is when the second ball rests in the hidden trap. Multiball starts when the third ball activates the switch in the trough. However, the programing only looks for one ball against the lever, and one ball activating the switch at the same time. It does not matter if there is not a ball in the other "trap".
    Found then out when I put the second wire ramp back on the playfield and aparently didn't wire up the ramp switch correctly. When the ball went down the second ramp, the switch didn't activate, so the game didn't tell the first ball to leave the trough. So once the second ball landed in the trough and activated the switch, multiball started.
    So yeah, to sum up, when it happens, its either an accident, or a switch error.
    It can happen with all switches working as well.
    If the "Power 1" ball attempts to kick out and FAILS when Ball 2 is coming down the second ramp, both balls will end up in the lock area and start multiball.
    RawleyD said:
    EvilJack said:When the ball went down the second ramp, the switch didn't activate, so the game didn't tell the first ball to leave the trough. So once the second ball landed in the trough and activated the switch, multiball started.
    Yeah events why I said accident. Never ment to imply it only happened with a switch error.
