(Topic ID: 30084)
Playfield Dimple Reality Check
By vid1900
11 years ago
  • 303 posts
  • 114 Pinsiders participating
  • Latest reply 5 days ago by vid1900
  • Topic is favorited by 56 Pinsiders
2 key posts have been marked in this topic
Display key post list sorted by: Post date | Keypost summary | User name
Post #281 Compressed wood in ball travel areas Posted by vid1900 (5 years ago)
Post #282 Measurement of compressed wood in ball travel areas Posted by vid1900 (5 years ago)
Topic indices are generated from key posts and maintained by Pinside Editors. For more information, or to become an editor yourself read this post!
There are 303 posts in this topic. You are on page 1 of 7.
31
#1 11 years ago
13
#2 11 years ago
And a normal, unprotected area of the playfield here:
46
#3 11 years ago
So this should show you guys that even a lightly played Williams 90s game has millions of dimples.
After a while, you get so many dimples that all the wood fibers are as compressed as they are going to get and it "seems" smooth, but really isn't.
In the next few months, I'm going to put a good clear coat over this playfield to protect it, but that will not stop the dimpling.
The Stern playfields are still made by CCC, the same company that made most of the Williams playfields.
Once and for all: it's not new cheap wood, it's not Stern sucks, it's not crappy clear coat - it's just pinball.
#4 11 years ago
Great post.
Tall Man dispelling rumors once again.
#5 11 years ago
Yer bummin' us out vid.
#6 11 years ago
Great post!
#7 11 years ago
Even WOZ will dimple the same way. It's just the way it is.
#8 11 years ago
Nice post. Thanks!
#9 11 years ago
I had a super nice HUO NGG. It had dimples in the PF. While some thought this was a negative, in a way it actually showed it hadn't been played much because they hadn't evened out much.
#10 11 years ago
Thing is, there are SOME playfields that just don't ever get dimples, why is that?
31
#11 11 years ago
Quoted from DNO:
My Orbitor 1 does not have any.
#12 11 years ago
Quoted from vid1900:
LOL....
#13 11 years ago
I don't understand you mean that a steel ball can dimple wood???? That just doesn't make sense. Haha Pinball people are funny.
#14 11 years ago
Quoted from DNO:
Is it because they are completely dimpled? And therefore, you cannot see the dimples?
#15 11 years ago
How are dimples actually formed? Air balls? Are air balls really that widespread?
#16 11 years ago
Quoted from Crash:
Yes for sure, but they are mostly formed by the ball changing direction rapidly and skipping across the pf a little bit. They add up over time.
#17 11 years ago
just another pic for vid and everyone. william 94 dh pre clear coat used pf;
#18 11 years ago
^ another great example.
#19 11 years ago
Quoted from Crash:
Not just air balls, but balls that bounce off of posts and targets.
Of course balls that drop from ramps make many dimples too.
#20 11 years ago
Great example vid. Love that the orbitor 1 has none. =-)
Logic dictates that most woods are softer than most metals..... Pretty sure over time this will happen to even the hardest of woods.
#21 11 years ago
Quoted from Shoot_Again:
Yes, no doubt.
But the best part is; the more dimples you get, the flatter the playfield becomes.
So play the crap out of your games to compress all the wood fibers you can.
1 month later
#22 11 years ago
Do Mirco playfields dimple worse because they have so much clear coat on them?
// Error: Image 63154 not found //
#24 11 years ago
Quoted from Concretehardt:
Nope.
Steel ball = harder than clear coat.
3 months later
#25 11 years ago
A buddy is trying to get me to use a epoxy 2 part clear coat over a fathom playfield? He claims it wicket hard and applys thick and is water clear , I thought it would be soft ?... I still might have the auto body guys apply an auto clear ... Anybody have any experience with epoxys ?
#26 11 years ago
Here is another reality check: I have seen NOS playfields from the 80s with cupped, raised and/or loose inserts. Installing LEDs under them would not have helped because they never had ANY lights installed under them.
#27 11 years ago
Quoted from Dawson:
Epoxy usually yellows over the years. Too hard and the coating might crack.
And, the epoxy clear for bartops says to sand the wood with 80 grit so the epoxy has some tooth.
Stick with auto clear.
#28 11 years ago
Quoted from John_I:
Yep, lots of NOS playfields with cupped inserts, especially if they don't have the jeweling on the backside.
They were only made to last 3 years, not 30...
#29 11 years ago
Quoted from DNO:
Show me these playfields. I guess if you never play your machines and enjoy them it's possible. I have never seen a non-dimpled playfield.
#30 11 years ago
Quoted from ChadH:
Clearly you are not familiar with the legendary "fit & finish" and build quality of WOZ. Nothing can hurt it; especially pinballs smacking down on the playfield.
#31 11 years ago
Quoted from xbloodgreenx:
It's probably because all the dimples have been compressed already... looks flat because it's ALL dimpled.
#32 11 years ago
Quoted from Fatsquatch:
thats because at this rate none of the playfields will ever see a ball lol
#33 11 years ago
#34 11 years ago
Wondering: on ACDC, since the cannon essentially delivers an air ball with every shot, are the middle of those playfields going to see a pattern of accelerated wear in the landing zone?
#35 11 years ago
Quoted from Nuclear_Waste:
Yes
#36 11 years ago
I've yet to see the cannon directly drop a ball on the lower playfield.
#37 11 years ago
My DH has no wear that could be attributed to the gun (which is just a cannon by another name). I thought about protecting this area more, but hey, it survived a route without it.
#38 11 years ago
Quoted from swampfire:
I think it's all luck. My DH has some divots for sure...but I never remembering noticing anything big on STTNGs that i've played.
#39 11 years ago
Quoted from TheLaw:
I think it has something to do with owning the game. When its yours you inspect everything with a fine tooth comb. Also, It would take a long time for the dimples to even out in home use.
#40 11 years ago
Nice pictures, I never really thought about a playfield having that many dimples. I always thought people were complaining about the ball drop areas, some of my games look like these pics and I just though it was orange peel in the clearcoat from the factory.
#41 11 years ago
I wonder what they use on bowling alleys? Now those get some serious abuse.
#43 11 years ago
Quoted from Hammerhead1550:
maple and pine... maple where you walk/where the ball lands, and pine further down...
#44 11 years ago
Those are dimpled too. Had to retrieve my kid not too long ago and got a nice close look, if you know what I mean.
#45 11 years ago
Quoted from Pafasa:
lol... yes, if one was to examine a bowling alley as closely as some examine their playfields, they'd be shocked at what they'd see...
1 month later
#46 10 years ago
The Janka test (the way we determine the hardness of wood) is measured by the force required to drive a 1/2" steel ball 1/2 way into a piece of wood.
There is no wood harder than steel, so that is why they use a steel ball as a measuring device.
Maple (the wood use to make playfields) requires 1400 lbs of force to bury the ball 1/2 way.
Australian Buloke wood requires 5000 lbs of force; so in the larger scheme of things, Maple is not that hard of a wood.
#47 10 years ago
Hey Vid1900
Thanks for the very informative post.
And BTW.. if you have anti-glare glass..it just makes the dimples even more apparant.
So you have to figure out if you are a player or a collector. If you are a collector and you don't want any dimples...then just don't play it.
Like you said..."its pinball'
#48 10 years ago
Quoted from joeraptor2003:
Right on.
Sure, I like to keep my machines as nice as possible, but if you're gonna play them, shit's gonna happen. You've got a big metal ball bearing hurdling around at great speeds, knocking off of wood, plastic, and glass...some of those materials are gonna suffer damage.
As a player, I'm not much bothered by any "natural" damage that happens as a result of my games being used and enjoyed. But then again, I'm not one of those guys who spends all their time, money and energy on decorating and modding machines instead of actually playing them.
-1
#49 10 years ago
Agreed. Steel Ball, Wood and Physics. It really is that simple
#50 10 years ago
At first I was thinking that you named it after someone at work, but then I googled it.
http://en.wikipedia.org/wiki/Janka_hardness_test
Even has a Wiki.
$ 6.95
$ 19.95
6,250 (OBO)
Newton, NJ
$ 50.00
Duke Pinball
YouBentMyWookie
Mitchell Lighting
6,900 (OBO)
Springfield, OH
$ 89.99
Filament Printing
6,500 (Firm)
Yonkers, NY
$ 19.99
PinballGeek
$ 26.95
$ 9.99
Bent Mods
$ 160.00
Sparky Pinball
$ 14.95
$ 599.95
Hi-Rez Pinball Mods
$ 16.00
$ 259.99
$ 29.95
$ 54.99
Glendale, AZ
$ 12.00
$ 1.49
Daddio's 3D Printed Mods
This page was printed from https://pinside.com/pinball/forum/topic/playfield-dimple-reality-check and we tried optimising it for printing. Some page elements may have been deliberately hidden.
