First, I really like the "low scoring" option. I'm testing the app now and if I can get it working there's a decent chance I'll use it for the pin golf at pin a go go.
I thought about emailing this but it occurs to me others might be having the same problem. I just loaded 1.62. It's the first and only version I've ever installed.
When I go to make a tournament, add players, machines, etc then click Start Tournament, I get a fault. Here are the details.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.UnauthorizedAccessException: Access to the path 'C:\Program Files\Danesi Designs\2013-05-18-Pin a Go Go.trn' is denied.
at Microsoft.VisualBasic.FileSystem.FileOpen(Int32 FileNumber, String FileName, OpenMode Mode, OpenAccess Access, OpenShare Share, Int32 RecordLength)
at ArcadeTournamentManager.frmSetupNewTour.Button1_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5466 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
Arcade Tournament Manager
Assembly Version: 1.6.2.18495
Win32 Version: 1.6.2.0
CodeBase: file:///C:/Program%20Files/Danesi%20Designs/Arcade%20Tournament%20Manager/Arcade%20Tournament%20Manager.exe
Assembly Version: 8.0.0.0
