(Topic ID: 59642)
Nightcrawler not popping up!?
By Zampinator
10 years ago
#1 10 years ago
Right Nightcrawler not popping up. Did a coil test, nothing. Left works fine. Found a 3amp fuse under play field (2 side by side). Replaced it with a 7amp (all I had). Did another coil test & the small coil that allows the Nightcrawler to go down now works. Go to try the coil test to fire the Nightcrawler up & nothing! Try again, smells hot! Unplug pin, & coil that fires Nightcrawler up is crazy hot! Took the 7amp fuse out & now waiting for the hardware store to open tomorrow.
Any ideas what's going on? I need some help?
Thanks, Zamp
#2 10 years ago
Do you have the RevA aux board? My NC had issues and they were all on that board. Get in touch with Stern and your distributor right away if you need the RevB board.
#3 10 years ago
Sounds like a bad aux board I would contact Stern 1800-Kickers
#4 10 years ago
Nice! No. I've had no issues. Everything is bone stock. They will warranty it?
#5 10 years ago
Quoted from Zampinator:
Nightcrawler not popping up... Any ideas what's going on? I need some help?
Thanks, Zamp
You own an Xmen Pro?
I keed. I keed.
Good luck with repair. Stern will help you out.
-1
#6 10 years ago
Quoted from Rick432:
I keed. I keed.
Funny! Kick a guy when he's down!
#7 10 years ago
Sounds like a classic 8 transistor (aux board) failure. You'll need your distributor to issue a PO for Stern to send an advance replacement board. You should put an ohms meter on your 4 NC coils to see if any have failed. Stern will take care of it.
#8 10 years ago
How many ohms should it read?
#9 10 years ago
Dude, save yourself time and listen to the posters. It's a bad aux board. I had the same exact thing happen to my old X-Men and I'm 99.8% sure that is your issues.
Also, stop speculating. Call Stern and find out if they will replace it. You could have done that in the time it took you to type your speculative post.
Good luck.
#10 10 years ago
Quoted from eggbert52:
Good luck.
Dude! Already called Stern! Already boxed it up! Its on a FedEx Ground truck on its way to Chicago!
I was asking Because i was going to return the coil as well with aux board if it didn't check out with the ohms meter. Dude!
#11 10 years ago
Seems mine just crapped out. Arrggh!
#12 10 years ago
Quoted from SealClubber:
Check the ohms...
#13 10 years ago
The up-kick coil is 4.55 ohms. If I remember correctly, the small release coil is around 54 ohms.
#14 10 years ago
Quoted from LP30:
Roger that. Thanks.
#15 10 years ago
How many plays on your pin? Just curious.
#16 10 years ago
Not sure as I have done all the updates and never kept track. Not that many to be sure. I hardly played it back during that suckfest-of-a-Xmas-present-code and I am gone a lot due to my job.
Pin Monk
$ 5.00
3D Tech. Pinball Parts
6,500 (OBO)
Clinton, OH
Professor Pinball
Trade
Machine - For Trade
Coos Bay, OR
NO GOUGE PINBALL™
Pin Monk
$ 225.00
Professor Pinball
Lighting - Backbox
$ 54.99
Pin Monk
This page was printed from https://pinside.com/pinball/forum/topic/nightcrawler-not-popping-up and we tried optimising it for printing. Some page elements may have been deliberately hidden.
