Need close up pics of F-14 Tomcat spinner
Started 1 year ago by vid1900 in forum All Pinball.
Forum » All Pinball » Topic
  • 120 karma points were scored in this topic
Tags
No tags yet.
    I'm restoring a F-14 and need some closeup pictures of the spinner.
    The one I have, I'm not sure is original.
    Does somebody have the game and KNOW for a fact that they have the correct spinner installed?
    TIA
    not the best pics but hope it helps...
    Thanks, you rock!
    Can you uncrop a little so I can see the wire bend on both sides of the target?
    Unless you're absolutely against it, I recommend the F-14 decals on ebay. I ordered the new Yagov & Landing/Lock decals -- they look fantastic, were high quality, and shipped fast.
    Hope these work better. Zoomed out a bit
    OK, I see yours has the nylon washers at the switch shaft, but not on the two ends.
    The one on my machine has a total of 4 nylon washers on it.
    Is that how everyone's is?
    My FT spinner is setup just like this with the two nylon washers...
    Mine has three on one side (switch arm side) and one on the other. Two are on either side of the switch arm and two are on the extreme end of the support wire where they meet the bracket
