Anyone got a manual for this game? I need a copy, PDF, Jpegs, whatever you have.
Turret magnet wil not engage, and the rotate and fire buttons don't work.
I need to figure out where to start troubleshooting.
Thanks in advace
Jeff
Thanks in advace
Jeff
Brilliant! Thank you so much!
On the off chance you might know, all the target switches on the root shooter say they should have a .05MFD cap, but none do. Should I add caps? And can I add different values? I'm not sure what they are but I have some that are avx 40J NPO.
dont worry about the caps.. wont effect it working.
Quoted from Tridentphoto:Brilliant! Thank you so much!
Don't worry about the caps. Wont effect it working. A good starting point when dealing with your roto shooter is to start by cleaning all of your contacts. After that take the two screws out of the rotating motor part.. next to where the wires come in from the relay.. you will see putty covering the wires.. take the spinning mech out and grease it a little bit. Also clean the contacts on the spinning board that rotates. check your header pins and connectors on your solenoid board for any damage. Honestly it is probably a dirty contact issue. Cleaning them should fix most of it. If not message me and I can help.
Thanks for the reply, I got it all working several weeks ago. It was the circular circuit board that had an issue. The power wasn't getting from one side to the other via the rivets. I resoldered them and it worked fine.
Now I'm waiting on a custom 3D printed snake to replace that plastic that's stock. I designed it and sent the file to get printed. I hope it turns out. I'll likely paint it metallic silver to go with the game.
I'll post a photo when it's done.
Jeff
This page was printed from https://pinside.com/pinball/forum/topic/need-a-stern-viper-manual and we tried optimising it for printing. Some page elements may have been deliberately hidden.
