My Pinmame Cabinet, almost done, just need glass and sideart. I took the design from my Star wars Pin with the DMD reflecting down into back of the lower cabinet. It is the exact same size as a pin 2000 cabinet except the head is smaller and shorter by 6 inches. the cpu is mounted in the head behind the 23" monitor to get easy access to it from the back, also easier to cool. The sub is in the bottom cab with the 37"lcd and has 2 cooling fans vented at the back.
For the sideart I am thinking something along the lines of Big Bang Bar but with characters from other pins included in the mix. But the same colour scheme as BBB.
I have left the side art as decal areas like a pin2000 just to make it easier to change it up later if I want to as well.
I also wanted to keep the buttons as simple as possible. 4 flipper buttons, Start, Exit, Plunger/launch. you add credits on some tables that are not freeplay by pressing thd coin return buttons.
Yes the plunger actually works for most games, it is true analog so you can do skill shots depending on how far you pull it back. It also has a nudge/tilt sensor so nudging affects the ball and too much tilts the table.
The last pic is another work in progress.
P110511_19.43.jpg P110511_19.44.jpg P110511_19.47_[01].jpg P110511_19.43_[01].jpg P140311_15.30.jpg
