Bought a set for my Tron, missed a good number of things I needed for the FULL set, but I got all the major stuff covered.
Do you like your games to play fast? Do you like your flipper rubbers to catch the ball almost as if they had sticky fingers? Do you want your slingshots to play like someone put a Jagov Kicker in them? Do you want to see rubber rings on a pinball machine glow?
If you answered yes to all or some of those, you're probably going to be interested in this stuff. These are some WIERD rubbers. I replaced most of the stuff I had on Tron last night. The only thing I didn't get was a few of the vertical posts and the mini-bumper-posts. I would estimate that these rings are "harder" than black rubber. If for instance (I don't know actual numbers, just making a comparison!) you say on 1-100 scale, higher is "harder", that white PBL rubber is a "40", but black Wico rubber (off a NIB stern) is a 50, then I would say this stuff is like a 57-60. There's that much difference.
It plays FAST and brutal, and it can bounce a ball from a held-up flipper out of the Tron scoop all the way up into the pop bumpers if it hits the flipper just right. The slings are so stiff and tight that I'm actually going to have to close up the gap on my switches, because the slings aren't soft enough to allow a mid-speed ball to trigger them, whereas on black rubber it would trigger almost every time they were touched! When they DO go off, it's usually a pretty violent interaction. I haven't played it enough to say for sure, but I am a *bit* concerned with it potentially causing a lot of airballs.
I shopped out Tron last night, so my disc is nice and clean, and the transparent rubber is back in the disc area, which is a LOT brighter now that it lets all that light through. This is really the strong point of these things... if you want a bright playfield that plays like a tough black rubber set without leaving all the scudge and gunk and darkness, this is for you.
My only other thought is that these rubbers are so hard and fit so tight to equivalent sized black rings, that I am moderately concerned about their durability. I did have one small ring snap when pushing it down over a post last night because the ID of the hole wasn't a good match to the equivalent size rubber, it was smaller. I put the other ones that went on post on with a pair of needlenose pliers and it was fine, but just trying to roll the thing on the post....it snapped.
Pictures incoming!
