I made a huge mistake, I waxed my metallica and it is soooooo freaking fast that I have a hard time to even see the ball let alone play, how do I remove the wax??? lol
Alcohol or dish soap. I don't claim either is safe, but I've used both to remove wax and novus residue. I get rejects off the drops like crazy after novus residue is on the playfield and/or balls so I've cleaned the playfield back to non-wax a few times. Yes I know novus isn't a wax, I'm just saying its residue is 'wax like'
Ok, the real reply
In my opinion, You can never wax your PF enough. Faster, the better. I wax with a 4 piece drill buffer. I wax it till I see my face in its reflection.
For years I only use alcohol to clean the playfield and hardly use any wax. Ok, the pf will not be as fast with wax but will stay cleaner for a longer time.
Quoted from Der_Meister:will stay cleaner for a longer time.
Alcohol will break down wax. It will make it cleaner in terms of eating food on your playfield but will not "protect" your PF. If you only use Rubbing Alcohol for many years and not wax, you must be down to factory clear-coat or ink by now? Consider "WAX" as the layer of your eye" You need a layer to protect yourself from the elements.
This is the facial expression I expect after I wax
AFTER_I_WAX.jpgThe games should be waxed and should always play that way. I suggest resistoring down the slingshots slightly and keeping things spotless and waxed.
Quoted from markmon:I suggest resistoring down the slingshots slightly
Quoted from mario_1_up:just play until the wax wears off.
Lol that's what I did cause after I used novus I also got target rejects.
they have a cleaner wax that removes wax and the like but is not bad on clear coats.. any auto part store has it I like turtle wax products... cant wait for my STLE and turtle wax ice that thing up!
Quoted from misfitdart:I made a huge mistake, I waxed my Metallica and it is soooooo freaking fast that I have a hard time to even see the ball let alone play, how do I remove the wax??? lol
I bet you have the Randy save at max
For you guys that don't know what that is,it's the ball save timer.
We max it out for the op,he's not that good of a player
With that nicely waxed playfield he probably plays less.
The clearcoat on a Stern is paper thin.
Wax the crap out of it before the first play.
Also, let the wax build up over time. Just buff it real good when it starts to look dull.
Been saying this for awhile . Don't wax your new games,it makes them unplayable !
Quoted from pingod:I bet you have the Randy save at max
Thx Dan that helps, you have an le so I don't think you see what I mean about a FAST playing game......lol
Quoted from McCune:Been saying this for awhile . Don't wax your new games,it makes them unplayable !
Lol, I couldn't imagine doing that to ACDC as well since its already extremely fast. I did get it in March though and haven't cleaned it yet...better do that soon.
I just wiped my playfield with novus 1, wiped off residue with another rag, its playing nice & fast + also seems to have stopped air balls off the right sling
No where in any documentation Stern or JJP provides (to my knowledge) is waxing recommended. Cleaning yes, waxing, no.
Keeping things clean, and using good clean unscratched pinballs will do more than waxing. Waxing will obviously help, but at the cost (imo) of too-fast ball speeds and more airballs and broken plastics. Drop targets will break folks
Just my 2 cents.
Quoted from markmon:The games should be waxed and should always play that way.
In your opinion.
Waxing can make the pin pretty unplayable until the wax wears off to a degree.
There is no reason to wax cc'd PF's. It makes them much too fast. Balls start flying places they should never go, you will crack way more plastics/ramps/whatever. Wax is for non cc'd PF's IMO. Novus clean and buff with a dry paper towel is all I do, and they are super fast at that.
When I got into this I waxed my TAF once... I was firing center ramp shots so hard that I killed the upper left switch on the ramp.
The speed designed was not based on waxing.
Quoted from HOOKED:And look what I found on a hinge. Just snapped a picture today to start a thread.
I have no idea what I'm looking at?
Quoted from RobT:I have no idea what I'm looking at?
Looks like the number for Stern tech support.....
look at the left hinge support. Do you see hi on it? took me a bit to notice it the first few glances.
Quoted from Atomicboy:The speed designed was not based on waxing.
I don't know about that. Friction on a game isn't exactly what we should shoot for considering all CC's wear down over time. A playfield should be treated like a new car with a clear coat. Some people wax them every weekend to keep them shiny hoping that little bit of extra protective coat keeps it shining that much longer, yet other car owners never wax them... ever. The difference is cars don't have pinballs running across their surface.
You choose whichever makes you happy, it's your game, and in a HUO environment it may not matter for many years, even decades, down the road. But in the end if I had a choice between purchasing a game or car from two parties, I know which type of owner I'd prefer to buy from.
Quoted from Baiter:A playfield should be treated like a new car with a clear coat
Yeah because my games sit in the sun all day .
Quoted from Purpledrilmonkey:No where in any documentation Stern or JJP provides (to my knowledge) is waxing recommended. Cleaning yes, waxing, no..
My NIB Tron absolutely had a sheet instructing you to wax at least monthly.
Quoted from McCune:Yeah because my games sit in the sun all day .
Do you rub your balls on it all day long? Pinballs that is!
Quoted from markmon:The games should be waxed and should always play that way. I suggest resistoring down the slingshots slightly and keeping things spotless and waxed.
Can you explain how to resistor down the slings, please? I assume this will fix the mega powered-ness of the slings.
I use CP-100 pinball cleaner/polish. Its liquid and can go on the pf and all rubber parts without drying them out. I have been using on all my pins for years. I definitely notice a speed difference after application. It's much faster to apply and not as labor intensive as waxing, with no worries about build up of any kind. I highly recommend the stuff!
This page was printed from https://pinside.com/pinball/forum/topic/metallicaholy-crap and we tried optimising it for printing. Some page elements may have been deliberately hidden.
