So I had a snagger issue. The drop target wouldn't drop. Finally found a wire (white with green stripe) had broke off the snagger coil assembly. I soldered that wire back on. Tested the game. The game booted and coil 4 I think for the snagger drop target kept firing, the start button would not start a game and the launch button started a game.
I replaced the bridge rectifier, bridge21 for 5v, and connected te game back. Checked the drop target assbly, found the diode going across the coil touching the nut, so I bent that over so it wasn't touching. The game boots with a random coil error but it went so fast I couldn't read. Start button doesn't work. I went into the menu, the menu buttons on the door are almost turbo charged. They are pressed and fire multiple times. Here is the switch test of active switches. As you can see many are active without being touched.
Any ideas?
