Need some help with upgrading my LOTR... I need help finding the three roms for my "LE"... I need that motor shaking...
Anyone?
I found the GAL and loaded the firmware. How do I know if the shaker will work before I buy a shaker kit?
I didn't see any shaker settings in the portal menus like I do in my Tron. Was this normal in the LE version back then?
Yes it was normal. That is why it isn't as effective/nuanced like the TRON coded shaker. The LE's were just pre-wired for plug and play shaker installation, as well as the 10.02 roms installed.
But still, it is a great addition! Also the colored wires for the shaker were mismatched on the LE as well. (2 pin, located at the back of the cabinet. Brown with blue stripe from shaker connects to blue with yellow stripe wire in cabinet.) It is okay to connect them together...
Good luck with the setup.
I thought that you couldn't just use the LE code and add a shaker. Am I wrong??? Is that all there is to it? I was under the impression that a lot of other things had to be done to get it to work.
Thanks for all the info. Any FAQs or documents on wiring the shaker to a non-LE machine that someone here has used and can verify success with it?
I thought Abbe just installed one on a non LE??? (John for ROM's and Pinbits for PAL/or possible shaker wiring sans board.)
You can also PM tatman if you need more help. (I seem to remember him knowing more about it the last time this thread came up... )
Hey all little off subject but I saw some alternative sling (LOL EDIT) shot plastics on ebay thought I would post a link in case any of you are interested in them. Bit pricey but here they are anyways:
ebay.com link: Lord Rings Pinball Alternate Slingshot Plastics
Quoted from The_Dude_Abides:sling blade
reminds me of the movie!Can I have some French fried potatoes?
This page was printed from https://pinside.com/pinball/forum/topic/lotr-1 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
