(Topic ID: 29236)
Lost World: Jurassic Park - CLIFFY!
By northvibe
11 years ago
  • 46 posts
  • 12 Pinsiders participating
  • Latest reply 9 years ago by northvibe
#1 11 years ago
To Cliffy or someone near Cliffy with a JP Lost World. We should try to get a cliffy made for the baby t-rex hole...which I am forgetting at the moment, the technical name.
#2 11 years ago
Pics
#3 11 years ago
Man that looks like my GnR Axl scoop protector would fit!
#4 11 years ago
Quoted from Cliffy:
It looks SUPER close. The JPLW looks like the rear screw is just a little different. I could get the GNR and test fit/trace for ya...Or see about doing a trace on hard paper and sending it over? I have to rerubber it soon so I'll have time to tear it down.
#5 11 years ago
gnr
#6 11 years ago
Quoted from northvibe:
#7 11 years ago
scoop? what..why are YOU blushing
1 month later
#8 11 years ago
you do it to me parn..
#9 11 years ago
Emoticon fail.
#10 11 years ago
I'm actually curious if this ended up working as I have a buddy picking up a JP-LW in the next few days...
4 weeks later
#11 11 years ago
Cliffy, I have an LWJP and I'm down in San Jose CA.
Let me know how I can assist with this project.
Thanks,
Derek
1 month later
#12 11 years ago
Yes any updates would be awesome. If cliffy wants to work with me or someone close, lets go for it I know it wont be pnp but it will be close.
#13 11 years ago
I need on too!
#14 11 years ago
GnR Axl won't work so I still need a PF.
#15 11 years ago
Quoted from dud190:
Thanks,
Derek
get to cliffy
2 months later
#16 10 years ago
Does anyone know what the exact material cliffys are made from?
When I get time I will measure and laser cut some stainless shim stock and bend one up.
IF it works out I could probably make a couple extra or post the .gfx file.
Milton
#17 10 years ago
Hi Folks,
I have the pattern programmed for the cliffy. What grade and thickness are the material?
Thank you for your time,
Milton
#18 10 years ago
Would you be up to collaboration?
Love, Cliffy
#19 10 years ago
Hi Guys.
Quoted from Cliffy:
Love, Cliffy
Sure. I have the part programmed and cut out. I have a couple of protos done. Need to drill the holes as I did not EDM them
I'm unsure of the grade stainless that I used. (shim stock) 10 thou thick. NOT 308.
When bending the "tabs"down some of them crack along the brake line. I will post some pics Mon or Tues. Pretty beat now.
It covers the entire hole not just three sides.
Milton
#20 10 years ago
Here are the photos: (Sorry about the size)
cliffyinstalled.JPGcliffyinstalled.JPG goprocrack.JPGgoprocrack.JPG handbentnocrack.JPGhandbentnocrack.JPG protonoholes.JPGprotonoholes.JPG
#21 10 years ago
Cliffy: These were cut on an EDM. I had the holes plotted but it would have required two re-threads
of the wire and it's a pain. I would have to drill two small pilot holes for the wire anyway.
These were cut from .010" shim stock all at once. (Sandwiched) I suppose you could cut as many as you want at one time. I may try cut some on the laser if my holes are plotted correctly.
Milton
#22 10 years ago
Here is the final proto:
Added more clearance for the baby t-rex.
I was going to add more width behind the scoop but I think this will be fine.
Milton
#23 10 years ago
If anyone wants a proto let me know. I have three without holes I will give away.
Milton
#25 10 years ago
Final "Cliffy" installed:
I have a few protos to give away if interested.
#26 10 years ago
Here are the freebies:
Couple have holes. Three do not.
#27 10 years ago
Nice work.
I am not sure you should call it a “Cliffy” since he did not make it.
#28 10 years ago
Quoted from pinballlooking:
Nice work.
I don't think he will mind. Kind of like "Bandaid". He has coined a new product ID.
IF he does mind I will edit the posts. I'm easy to get along with. Just ask my wife.
Milton
#29 10 years ago
This is really needed on JPLW I have sold mine but if I still had it I would want one.
#30 10 years ago
They all seem to wear.
Before, during and after.
maskit.JPGmaskit.JPG fillit.JPGfillit.JPG getting_close.JPGgetting_close.JPG Cliffyinstalledfinal.JPGCliffyinstalledfinal.JPG
#31 10 years ago
Pretty nice job considering all you had to work with Milt!
#32 10 years ago
Quoted from Cliffy:
Thanks, Cliffy.
I think the EDM does a better job then the laser but you must drill starter holes.
Perhaps a combo. Use the laser to "punch" holes and then cut on the EDM.
My friend is getting a new waterjet soon. That might be the ticket! You could cut about a thousand at one time! Same with EDM but much slower cut time.
Hope you don't mind me using the term "Cliffy".
IF so let me know and I can edit my posts.
Milton
#33 10 years ago
To everyone that has a proto: Please report how it fit. Especially the people who received the ones
with holes. I would like to know if the holes line up.
Milton
#34 10 years ago
I would be up to test if you still have any left!
#35 10 years ago
Sure! I only have two left without holes. The holes are marked but not drilled.
PM me your address. I won't be able to mail until Monday. (Just left P.O. Brian's is on the way!)
Milton
#36 10 years ago
I already got some on the way from him. No need to get another set.
Quoted from Milton187:
Sure! I only have two left without holes. The holes are marked but not drilled.PM me your address. I won't be able to mail until Monday. (Just left P.O. Brian's is on the way!)
Milton
This is the friend I mentioned. No need to send us both a set. I'll use mine and be sure to report the results
#37 10 years ago
Tony....You never come visit me so I'll never have it hahaha. We need a date.
#38 10 years ago
Milton
Ah nevermind, Tony has it.
#39 10 years ago
Tony is a B. I'll need one now. Thanks!
#40 10 years ago
I will get mine on this weekend hopefully, I will let you know. And thanks again!
#41 10 years ago
Hey northvibe,
Do you need one? I think I have one left without holes.
PM cuz i'm busy with a copter on r911.
Milton
5 months later
#42 10 years ago
Should have some updated news on this!
1 month later
#43 10 years ago
Should be good
#44 10 years ago
Nice you also got a T standing target
5 months later
#45 9 years ago
Hi,
I know this is an old thread, but I have a LWJP pinball which would definitely appreciate a cliffy.
If you have any left, I would be interested to pay for the item to be shipped to Melbourne Australia.
Any information would be appreciated.
Regards
#46 9 years ago
Shoot Cliffy an email
[email protected]
arcade-cabinets.com
arcade-cabinets.com
$ 6,999.00
Classic Game Rooms
$ 18.95
$ 17.00
Nordic Pinball Supply
$ 9,499.00
Classic Game Rooms
3,600
Livermore, CA
arcade-cabinets.com
Paradise Distribution
$ 18.95
$ 130.00
Dijohn
$ 18.95
$ 27.95
$ 1.49
Daddio's 3D Printed Mods
Pinhead mods
Arcade Upkeep
This page was printed from https://pinside.com/pinball/forum/topic/lost-world-jurassic-park-cliffy and we tried optimising it for printing. Some page elements may have been deliberately hidden.
