(Topic ID: 88645)
Jukebox player unit
By Gensega
10 years ago
  • 4 posts
  • 3 Pinsiders participating
  • Latest reply 9 years ago by Gensega
#1 10 years ago
I'm trying to restore a newly acquired Jukebox machine by Chicago Coin. I took out the player unit (which was seized). I got it spinning freely but I can't believe that this is the actual routing for this spring! It is clearly impeded by this arm and obviously caused this discombobulation in the spring. Can anyone else with a "Jukebox" confirm that this is the way this is supposed to be set up? I just have a hard time believing that this is correct, but it is the way I got the machine. Any help or advice here would be appreciated. Jukebox Player Unit.jpgJukebox Player Unit.jpgJukebox Player Unit.jpgJukebox Player Unit.jpg
#2 10 years ago
Bump for great use of language
Quoted from Gensega:this arm and obviously caused this discombobulation
#3 10 years ago
Looks correct to me, springs need replacing. the Arm on the right should be under the arm on the left, which limits the lift height and will make the pawls contact the ratchet gear. (center of your image)
This is a different machine, but the units are much the same.
#4 9 years ago
Thank you much. Its been interesting working on this machine without good references.
This page was printed from https://pinside.com/pinball/forum/topic/jukebox-player-unit and we tried optimising it for printing. Some page elements may have been deliberately hidden.
