The left flipper on my JP is behaving oddly. Sometimes, with the same ball in play, the strength is good and other times it is pretty weak and can barely get the ball up the playfield. I don't think the coil is binding or anything and the EOS switch contacts were cleaned and appear to be ok as well. I replaced the coil stop but it didn't help. The plunger doesn't appear to be dragging either. The diode is present on the coil but it looks like it is not the original solder job. Could this be the issue or could this be a flipper board issue? Any help is greatly appreciated.
