(Topic ID: 70192)
Is it possible to reproduce pinball plastics, including artwork, at home
By Rickwh
10 years ago
  • 85 posts
  • 33 Pinsiders participating
  • Latest reply 9 years ago by NextoPin
  • Topic is favorited by 52 Pinsiders
There are 85 posts in this topic. You are on page 2 of 2.
#51 10 years ago
I did a full shop out of LW3 using this method and it turned out sweet!!
http://pinside.com/pinball/forum/topic/pinsiders-in-the-nashville-tn-area/page/88#post-1300273
#53 10 years ago
Sticker method seems to work, but it looks horribly washed out. I think Crash did it right by using photopaper.
I'd like to chime in here of my experiment to adhere photopaper to lexan. I started by using a couple products I'm familiar with, mod podge (collages), and triple thick (for stopping flaking on backglass).
Trying this method a couple times, once with a foam brush and once with a putty knife. Both times I ended up with bad textured lines from the photo not completely sealing against the plastic, and because it dries too quickly (especially when you thin it out).
If you look through craft videos, you'll see lots of videos of transferring photos to wood where you use something called "acrylic medium". I got this 8oz jar off amazon for $7 (free shipping with prime), and it should go a long way since you spread it so thin.
It needs to be "medium" because this type tends to level out and stay smooth, where as a gel tends to keep texture (artists add this to paint to enhance brush strokes). Ignore the part where they wet down the paper backing, this will make it too translucent and you will lose color. Here's a test I did with this method and so far it's the most successful yet (I probably could have squeeged more of the glue out, there are still a couple bubbles in it), but with some practice I'm sure I could get it perfectly smooth.
Laser is reccomended. I did it with inkjet so I saw very slight bleeding, but if you squeegee it out you won't be able to tell. I would probably seal up the back too so that the paper doesn't flake over time.
Example video:
#54 10 years ago
#55 10 years ago
Spent the day with my brother working in the garage on some replacement plastics for my MET Pro. He brought over our dad's band saw, scroll saw and drill press.
We made two replacement plastics and I think they look great! Both plastics are clear with no artwork, but are fairly complex shaped. We modified both slightly to hopefully fix some design issues.
We made the plastic around the cross wider, and less pointy.
We made the plastic at sparky's feet wider so that it would keep airballs down.
Played a few games and it maybe my imagination, but it sparky hits are kept in control better. I need to put a few more games in on them, but I'm happy. Most of all it was fun!
#56 10 years ago
This thread needs more attention. Great work!
#57 10 years ago
Quoted from Crash:
#58 10 years ago
perfect!
#59 10 years ago
Quoted from Crash:
Seems like this scroll saw would be ideal.
I have a similar one (Craftsman) I got at OSH. Works pretty good for cutting plastic.
Robert
#60 10 years ago
I tested using a plumbing torch to slightly melt the edges of a clear plastic. It worked pretty good to remove the cloudy edge and leave a shiny more transparent edge. Will take some practice. And it think it would work better on a sanded edge. But better than the unfinished edge.
#61 10 years ago
Quoted from Rickwh:
I believe that's called flame polishing. There are videos on you tube and several threads about recreating plastics in the restoration section. Check them out. The decal method looks the easiest.
1 month later
#62 10 years ago
Quoted from Rickwh:
20131213_133501.jpg 109 KB
20131213_133249.jpg 113 KB
20131213_135722.jpg 201 KB
20131213_135729.jpg 255 KB
Are you planning on selling these? I'll gladly buy one should you start to produce them in larger quantities.
Thanks in advance.
Mike
#63 10 years ago
Quoted from herg:
When I bought my plastic protectors set from Pinbits, they sent me 3 different plastics marked "test". One was identical to the stock plastic, one extended to the half-way point, and one that was flush along the front edge. I ended up using the "medium" one, and it has drastically reduced airballs. I'm not sure what their plans were for making them available.
Uh, oh! I'm talking to myslef!
I'm pretty surprised that Pinbits isn't making these available in bulk. Mine works great, and I provided them with feedback saying so.
#64 10 years ago
just use a buffing wheel with some compound or even novus 2 on the edges should clear them up. Dont spend too much time on one spot you can melt the plastic.
#65 10 years ago
Man... I just got in from playing my METLE again tonight. This is a whole new MET, as a a few days ago. I have AC/DC next to it and like a magnet I'm pulled to the Metallica. This new code ROCKS! Great colors, great sounds, I'm really impressed!
Very Happy indeed!
#66 10 years ago
Ive had a few people PM me and ask me to make them sparky anti-airball plastics. Starting to get feed back and it seems people are happy with the results.
Im not wanting to setup a mod side business, but it seems the new code the the magnet is making the airball issue worse. So im happy to help out fellow pinsiders.
First round i did for $3 a piece. But the USPS was not so gentle with one customers order and they were broken in the package. So i am gonna bump up the price to $4 for any future requests and use better more expensive packaging. So pm me if anyone is interested.
#67 10 years ago
Hi Rick
I Pm you, but you deleted my Pm... really interested in your protector..
#68 10 years ago
great thread- thanks to all the contributors!
Once again, i have tool shop envy!
#69 10 years ago
Quoted from Redketchup:
Hi Rick
Sorry red, when i was at the post office the international rates are ridiculous. The cost of shipping would be far far more than a single plastic is worth. Just dont see it being worth it from your POV.
#70 10 years ago
Quoted from Rickwh:
Any chance to meet you at allentown?
#71 10 years ago
There's some nice work in this thread. I might recommend having your plastics cut on a laser cutter and then affixing the graphics. There's places like https://www.ponoko.com/ that can supply and cut the PETG for you if you draw the digital file. If you have a flat bed scanner, it's fairly easy to scan the plastic then trace out an illustrator or similar vector file. Just an idea in case you don't have a scroll saw or want a perfect looking cut.
#72 10 years ago
Heres an old vid I made for a poor mans plastics repro.
The best way to clean the edges is to cut the piece slightly larger about a 1/32" and use a belt sander or Dremel with sanding drum to take it down to the desired shape
Any large scratches can be taken out by using a straight razor and lightly scraping the edges.
Once smooth, finish the edges with a flame by torch or use a polishing wheel with polishing paste..
Flame polishing is quicker cleaner and less messy.
#73 10 years ago
I am taking a guess here. But if I were to try this after cutting out on the bandsaw or jigsaw, I would use a headlight polishing kit from any parts store. Also use some very fine wet dry sand paper 1000 to 2000 grit first then use the headlight polish to bring the shine out.
3 weeks later
#74 9 years ago
Im getting pretty good at cutting out plastics using a scroll saw and a drill press. But until now ive only done clear plastics.
Today i attempted with huge clunk of a failure to use the print on clear label and stick to underside of plastic method.... I dont have illustrator, photoshop, or an artistic bone in my body... So getting the image to print to scale was a mess. But after getting it printed and attached to the plastic, it was very dim washed out.. And the holes in the image didnt line up 100% with the new plastic... Sigh. I needed to put a layer of white on bottom to make it less washed out.
Need more practice.
#75 9 years ago
Toyotaboy, in your gel medium method, did you just use the medium basically as glue to stick the photo to the back of the plastic? Thats different than the video shows. Would you do this before you cut the plastic? I wondered how well it would stick and if the cutting would get shavings under the image.
#76 9 years ago
Quoted from JeffHecht:
Here are some shots of a couple of the plastics I recreated for Embryon. These are vinyl prints on PETG. I'll work up another post in the next couple of days on how I do this.
Jeff
DSC_5952.JPG 592 KB
DSC_5953.JPG 551 KB
Impressive!
#77 9 years ago
Sparky extended plastic over his feet, I'll be in for one!
#78 9 years ago
I completely reproduced the plastics on my Flip A Card. I posted my results in the huge show us your em thread. Here is a link to the page it's on: http://pinside.com/pinball/forum/topic/em-show-us-your-em-pinball-machines/page/40#postbox
#79 9 years ago
Quoted from Jeff_PHX_AZ:
Jeff, lemme know when you get ure met premium and ill send ya one!
#80 9 years ago
So here is my TFLE plastic recreation progress. Started pretty rough. But I'm getting there...
the plastic that sits between the left loop and the all spark on my TFLE broke. It is a two piece/layer plastic with artwork printed on the bottom of the top piece. The two pieces are riveted together with pressed rivets and the bottom plastic mounts (along with the all spark) to the left loop ball guide.
Heres the pic of the broken plastic and the replacements I got from my distro/stern.
My first attempt was to scan and print the art work onto clear address label stickers. I placed the sticker on the bottom plastic. It was washed out and the whites weren't white enough. To top it off my first attempt at riveting broke/cracked the plastic.
Next I moved away from the clear address label stickers to using photo paper. I also got more comfortable using gimp image editing and was able to edit the artwork to "remove the holes" from the scanned image. I also expanded the image to the size of the lower triangle plastic piece. I also get some gel medium as suggested above in this thread and used it to glue the image to the under side of the plastic.
The result was that the gel medium made the inkjet ink run and get blurry. Also there are some air bubbles. Still not good.
Last attempt I used the same photo paper image, but I used some clear rattle can paint to put a couple thin coats on the top of the photo paper image. Then I used spray adhesive onto the image and stuck it to the underside of a new plastic.
The clear paint kept the inkjet ink from running. I think this one is getting closer although not perfect.
I'll try one just like this last one, but using the gel medium as the glue to attach it to the plastic...
#81 9 years ago
Another update on my learning to make plastics with artwork.
With the recommendation from a few pinsiders on this and other threads I bought some clear and white decal paper from decalpaper.com.
I printed out my artwork on the clear decal paper. I included various versions of it including some flipped so that I could apply it to the back of the plastic.
Then I applied a couple thin coats of clear coat on top of the ink jet ink, so that it wouldn't run.
Then I cut out one of the images. Here is a pic of the new plastics from Stern on the left, third is my clear plastic, and forth is the cutout decal paper image (with top clear coat). Notice I didn't drill the holes in my plastic where the rivets would attach the original double layers together. I am going for just a single layer plastic.
#82 9 years ago
Then I put the decal in some warm water for a about 30 secs. until the paper back slides easily away from the decal.
I gently applied the decal to the back of the pastic being careful to keep the orientation correct. It was confusing with the image being reversed. I won't lie I messed up a couple times and had to print again...
Here is the decal applied to the back of the plastic, and the original Stern plastic.
Notice the decal is more transparent than the original. But when I put it on some of the white decal paper it looks pretty good with the white showing through.
So I cut a piece of the white decal paper with nothing printed on it. I just wanted to use it as a background for the original image. here is my plastic and the white decal paper cutout.
And finally a picture of the original Stern plastic on the left and my version on the right.
Looks pretty good I think! The color is a bit off where the Stern version is a bit more bluish than mine. I played with the color levels in Gimp, but I wasn't able to find something that worked to my satisfaction.
I was pretty happy with it... Until....
#83 9 years ago
When I installed the plastic in the game, I wasn't happy with it. It seems to stick out and not fit in with the game at all. Not sure why since I used the same artwork. Honestly when I put the new Stern plastics there they don't really look like they go with the game either. Maybe its cause I extended the image out where the Stern plastic is clear...
Here is a pic of the area of the broken plastic. The broken piece still partially in place under the allspark mount.
Then my new plastic in place
And a wider shot
#84 9 years ago
So I decided to scan the plastic that is mounted on the ball return area on the left side.
(I have to put something in the corner of my scanner or it cuts off the image edges. I use pennies cause they are flat and dont effect the scanning.)
I sampled the purple and the background texture and colors and made a new image to put on the plastic that I think goes better with the game.
Heres a couple pics of the plastic installed. (I didnt' take the time to make a take a picture before putting it in the game I was so excited...) I think it blends in much better now.
Thanks for all the pointers, tips and tricks from all the pinsiders out there!
1 month later
#85 9 years ago
I haven't done any pinball plastics yet, but I did build my kids a giant touch screen acrylic computer once (now replaced by an iPad). I used a dremel with a plunge router attachment and a saw bit for cutting the plastic (up to 3/8 thick). You can also mount the dremel to the underside of a router table or something and use it like a scroll saw. It works pretty good, If I recall I used a faster RPM, I think slower was melting the plastics, It's been a while, I made it for my daughter when she was 1 1/2 years old and she's going to be 11 next month.
http://www.doityourself.com/forum/attachments/patching-plastering/16318d1376451165-rotozip-vs-dremel-cutting-circles-drywall-rz-bit.jpg
$ 19.95
SilverBall Designs
$ 160.00
Sparky Pinball
7,000 (OBO)
Ronkonkoma, NY
$ 14.00
SilverBall Designs
$ 29.95
$ 69.99
7,000 (OBO)
Elgin, OK
$ 9.99
Bent Mods
$ 29.95
$ 16.00
Slap Save Creations
$ 55.00
The Flipper Room
7,000 (Firm)
Hot Springs, AR
Filament Printing
Pinball Z
$ 93.00
$ 4.95
Mitchell Lighting
$ 49.00
6,999
Downers Grove, IL
$ 1.00
Mitchell Lighting
Hookedonpinball.com
$ 99.99
$ 25.50
$ 12.95
$ 700.00
Hardware
Chrome Candy
$ 7.00
Pinball Z
$ 68.50
This page was printed from https://pinside.com/pinball/forum/topic/is-it-possible-to-reproduce-pinball-plastics-including-artwork-at-home/page/2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
