HS2: Volume Issue (solved); Rear Ramp Problem--fixed, thanks!
Started 11 months ago by Billy16 in forum TechTech: Generic.
Forum » Tech » Tech: Generic » Topic
  • Started 11 months ago by Billy16
  • 8 Pinsiders participating in this thread.
  • Latest reply from kehoe
Tilts/ ignores / abuse
Sharing and favs
Help us build a pinball game knowledge base by linking topics to the games discussed in them!
    11 months, 1 week ago
    I'm working on a Getaway I picked up over the weekend. Nice shape overall, but very neglected. Spent all afternoon re-sleeving coils, I'm sure that had not been done in many years.
    The volume can't be turned down past 8. Any ideas of why I can't zero this out and/or turn the volume down any further?
    Last issue (so far) is the rear ramp doesn't seem to know it is all the way up. The coil keeps firing (even though the ramp is already up) and the game will not allow the gear shift to plunge the ball until the ramp figures out is it up. Is there an interlock between the ramp and the plunger, maybe a short between the two, or should I look for a switch problem on the ramp?
    Thanks for any help--I'm sure there will be more...
    Dig around in adjustments and set the minimum volume over ride lower, then you can lower the volume more.
    There should be a "Min Vol Override" (or similar) option in the Adjustments menu. Switch it to Yes.
    Always check for switch problems first. In switch edge test, put the ramp in both up and down positions and verify the switches properly activate.
    A1.28 is your minimum volume override.
    Thank you all very much for the help, I'll get on it tomorrow!
    Billy16
    I had the same ramp issue, just needs a lil switch adjusting.. I just had to add a little more bend to it
    One of the tiny screws that holds the switch on my ramp was very loose and the switch didn't register correctly every time. The solenoid would fire 3-5 times to move the ramp but it didn't affect game play much. It bugged me enough to go looking eventually, and was an easy fix.
    Use the ramp test in diagnostics, which shows the switch status as the solenoids are fired in turn.
    Thank you all very much for the help, I'll tackle this this afternoon. The only drag is I'm missing a playfield skid, which makes raising the playfield a real chore...
    OK, I ran a check on the ramp switch--it seemed to check OK as I ran a "ramp check". Up and down, open and closed no problemo. Ramp still tried to fire "up" upon the start of the game. So I adjusted and adjusted and re-adjusted this ramp switch, things have only gotten worse. The ball used to plunge more often than not--as the ramp would finally quit firing "up". Now the plunger won't fire the ball at all. As soon as the first ball trips the switch underneath it (waiting to be plunged), the rear ramp tries to pop up continuously--even though it is up. If you skip the plunge and just roll a ball into the playfield to start, the ramp continually jumps up and down. Didn't used to do that. Do I replace or keep trying to adjust that switch--or where do I go from here? Sorry for the frustration, but this problem won't even allow me to play the game--bummer!
    Adjust the little catch on the small coil underneath, if the ramp doesnt catch it will just try to kepp going up repeatedly. I fixed this on a friends machine...
    Look underneath and move it by hand, you will see how it catches, then just adjust as needed...
    One of the best tools you need is your eyes
    OK, I will look at that, thanks.
    I had a similar problem with my ramp. In tests it would work fine but in game it would constantly try to go up at the start of the game and the ball wouldn't plunge. For me the issue was solely with the ball not plunging. There was some broken solder preventing power to the plunger. When I fixed the solder and stopped having plunger issues the ramp worked perfectly.
    Thanks for this, I think I will run this down as it seems like you have just described my main problem exactly. I think I just made things worse by adjusting the switch, I'll put it back to where it was and start over. Can you show (via a photo) or tell me where your problem was so I can check the same area?
    Billy
    My problem was with the solder on the plunger solenoid. I tested the plunger in the menu and it wasn't firing properly. When I looked at it the wires were poorly solder on. I cleared out the old solder, recut the wires, and reattached. I tested the plunger solenoid through the test menus and it worked flawlessly. I started a game and the ramp had no issues.
    I would suggest checking the plunger solenoid in the test mode. Is it firing at all? Is it firing half the time? I had issues there and once resolved the ramp worked.
    I will do that, this seems to be the exact thing I am dealing with.
    kehoe, you were right on the money. I had to solder one side of the coil twice before I finally fixed it--I believe the lug itself is almost shot but I was able to solder it back together. Thanks for helping me get my game up and running!
    B16
    11 months ago
    You're very welcome. It's nice to help out around here. I know many have helped me.
Wanna join the discussion? Sign up for a Pinside account, or sign in if you already have one.
© 2001-2014 Pinside.com All rights reserved. Jump to topRSS feedsHelpContactCookiesDesigned by Keeple
