Hi
Last week I get hook pinball. Almost everything works fine except that ball stuck in hole under the skull.
Have you any idea what can cause that situation ?
Regards
Damian
Hi
Regards
Damian
Does it land in the scoop and not kick back out from the lower right eject? Lift the playfield and see if there is a ball trapped in the subway somewhere. Also check the kickout coil for broken wires.
Hi
I found one ball behind playfield but still one is somewhere under.
But I have bigger problem - today when I was playing a display turn off and I felt some strange smell - something has burned.
Now machine doesn't boot. PIA led only turn ON for a while and there is hook,hook,hook. When I press START button it says "bad ball"
Regards
Yes, second hook is a mistake -- I will delete it.
When you say you hear "Hook," is it Tootles saying it three times or is it the other voice call you hear when starting a multiplayer game?
If the ball goes into the hole under the skull and doesn't eject from the lower-right scoop, it could possibly be one of the following: (1) the switch in the tunnel under the skull; (2) the coil that ejects the ball; (3) a fuse; or (4) the transistor that controls the coil that ejects the ball from the lower-right scoop. To diagnose, I would put the game in switch test mode and check the tunnel switch. Then, put the game in coil test mode and check the coil that ejects the ball. Depending on what you find, this should at least get you started in the right direction.
It sounds to me like the machine is booting. Otherwise, you wouldn't hear "bad ball" when pressing the start button. That means the game is not in free play and there are no credits. Try adding a credit and see if you can start a game.
Post edited by gseador : typo
This page was printed from https://pinside.com/pinball/forum/topic/hook-ball-stuck and we tried optimising it for printing. Some page elements may have been deliberately hidden.
