Selling these projects,(and maybe a few others) description below. Any questions let me know, thanx in advance:
Meteor: Everything seems to be working great. Needs complete shop. One leg bracket came loose from inside, couple of the displays are fidgety but sporadically work, glass has flaking mostly at the bottom.
6Million: Starts up and will play then flipper relay lets go. The game still goes and everything works correctly minus the flippers. Power off and back on the flippers will work a few times again. Has some minor touch up on cab, needs complete shop, has some battery corrosion to tend to, pf has some minor wear, back glass is GREAT.
KISS: Everything works great and no corrosion. This is a candidate for a full restoration and sell comes with all you need. The pf has been tore down but I keep getting side tracked. I have all the parts and pieces (minus new plastics) you need for restore, pf parts (complete pops, drops, posts rubbers, etc) decals, stencils, Gene shooter rod and more. Back glass is GREAT.
I also have (2) F-14 TomCat and a BK2K I MIGHT be willing to part with.
F-14(1): Real nice, plays great, LED display, some LEDs, nice cab needs pop adjustment at the moment, some raised inserts.
F-14(2): Real nice, plays great minus talking is quite at the moment I have not looked into this yet, mylar is removed and decals are on the inserts and some are raised. Some LEDs
BK2K: Very nice Pin with beautifully done LEDs, awesome cab, needs new pop skirt but have that and parts for flipper rebuild. I can add or send pics later.
