I am selling these mini projects as I just don't have time to work on them anymore. Trying to slow down on some of the pin work and play some for a change.
GNR, Nice playing game, some playfield wear at the Axle kick out. Otherwise excellent condition. No broken plastics other then Axle and I am throwing in a set of those plastics. All the ramps are nice with no cracks, etc...The game plays 100% correct however the sounds cuts in and out, (just a fuse). Just kidding. I have check wiring, replaced some connectors, etc.. Borygard checked the sound board and it is ok so I have no idea what the problem is. The cab is pretty nice however it is faded some. I am also throwing in a new set of cab decals. Translight and DMD are nice.
Asking $3,500. for everything.
Dr. Who.
I just opened this game up last night. The CPU will not boot up.LED's tell me there is something wrong with the RAM. That's as far as I have gone. Everything looks good. All the boards are clean, no hacks. I just don't know what works and does not since the cpu will not boot up. The cab is faded, as you can see in the pics. It is solid with no water damage. I do have a source for Cab side art but they are not included. The translight is nice. DMD works because I saw it flash a couple times. All the ramps look good with no crack, etc... Playfield plastics are unbroken with the exception of the left sling shot plastic. It does have the topper, playfield glass, etc..
Asking $1,300. for it as is. May just need a cpu board and your ready to go.
These are pick up in Fredericksburg, Va.
Going to bed now so if there are any questions I'll answer them in the morning.
Thanks,
Brian
