For Sale:
HOME USE ONLY Williams FunHouse Pinball Machine $6900 cash located in South Glens Falls, NY 12803.
Link to almost 100 pictures:
http://s793.photobucket.com/user/scottinsgfny/library/Funhouse%20HUO
It was purchased from the original owner who bought it new. I do not have documentation to prove but the pictures speak for themselves.
NOTHING has been cleaned under the playfield - check out the subway ramp!
Top was wiped clean but NOTHING was disassembled. Machine has the original rubber on it - which is starting to crack but I wanted to leave the machine as found for now.
There is not a full mylar on the playfield.
Flaws:
A little bit of wear on the scoops - see pictures
A tiny bit of wear around the edge of a couple of inserts - see pictures (Inserts are 99% level)
Little mark on translite
Some paint flaking on edge of backbox - looks to have had an adhesion problem to the primer they used at the factory.
Black Bolts on outside of cabinet have some corrosion.
Original Lock on Coin Door was drilled out as key was lost - replaced with new lock.
Battery Holder was replaced with an external Battery holder as original Battery Holder was corroded.
I would guess the machine has 500 plays or probably even less.
This FunHouse is clean and needs very little to make it perfect.
ScottinSGFNY
