Episode 3:
“You Can’t Get There From Here” or “The Logical Mystery Tour”
In this Episode:
Unmasking the Mystery awards.
Discussion:
One of the more confusing naming conventions in any pinball game is R&B’s multiple uses of the term Mystery. This is applied to four separate functions: Mystery Score, Mystery Award (a.k.a., “???”), Mystery Select and Super Mystery Select. What’s more, you can collect a Mystery Score from any of the other three and you can light Super Mystery Select from Mystery Select.
MYSTERY SCORE
Mystery Score is the most straightforward of the four. As mentioned, Mystery Score is not a standalone award, but is a pseudo-random award from any of the other three. When this is collected from Mystery Select it will award a random value of 5M, 10M, 15M or 20M (average 12.5M). When this is collected from Super Mystery Select it will award a random value of 15M, 20M, 25M or 30M (average 22.5M). When this is collected from the “???” Mystery Award then it can be any of the six values (more on that later).
MYSTERY AWARD (???)
The “???” Mystery Award is one of the 8 features collected from the WABAC machine (left ramp) when lit. It can randomly award any of the following (NOT in order of likelihood):
- Award Extra Ball
- Light Special
- Double Score
- Light Laser Kick [Added]
- Mystery Score (5M, 10M, 15M or 20M)
Removed: Although it appears in Keefer’s Guide, I have removed Light Mystery Select from this list as it does not appear to be a valid award in 1.30.
MYSTERY SELECT
Mystery Select is enabled by lighting all six letters in SELECT in the center of the playfield above the slingshots. Lighting the letters in select can be accomplished by:
- Completing the “Lite Select” skill shot at the beginning of the ball will light all six letters.
- A single letter is lit for each orbit completed.
- Completing sequential orbits spots two letters for each orbit instead of just one.
- Lighting the complete set of the three top rollover lanes lights the next letter.*
Once all six letters are lit solid, the “Mystery Select” rocket insert between the two ramps will also be lit solid to indicate Mystery Select is ready to collect. The “Lite Mystery” feature will be completed at the WABAC regardless of which method lights Mystery Select.
Mystery Select is collected by shooting the center shot between the two ramps and getting the ball into the scoop. At least on my machine, it will sometimes end up in the pop bumpers instead. Also, from the pop bumpers (however it gets there) it will sometimes end up in the scoop and start Mystery Select (if lit).
The possible Mystery Select awards** are:
- Already covered (at least partially) in the guide:
- Does NOT complete ‘???’ (Mystery Award)
- Light Hat Trick
- Save Nell
- Double Score
- Light Special
- Light Extra Ball
- The following WABAC*** features are available and will complete that feature:
- 10M
- “Super Pops” (light or advance)
- Light Looping
- Loose Moose
- Tri-Ball
- “Super Select” (aka, “Lite Mystery”; will light Super Mystery Select)
- Not listed in the 1993 guide:
- 10X Bonus
- Hold Bonus
- Light Laser Kick
SUPER MYSTERY SELECT
Super Mystery Select is enabled once all six letters in SELECT are flashing. Flashing the letters in SELECT can only be accomplished after all six letters are ALREADY lit solid:
- Completing the “Lite Select” skill shot at the beginning of the ball while Mystery Select is already lit will flash all six letters.
- A single flashing letter will be added for each orbit completed.
- Completing sequential orbits flashes two letters for each orbit instead of just one.
- Lighting the complete set of the three top rollover lanes flashes the next letter.*
- Colleting “Super Select” from Mystery Select will flash all six letters.
Once all six letters are flashing, the “Mystery Select” rocket insert between the two ramps will also flash to indicate Super Mystery Select is ready to collect. Again, Super Mystery Select is collected by shooting the center.
The possible Super Mystery Select awards are:
- Already covered (at least partially) in Keefer’s guide:
- Mystery Score (15M, 20M, 25M or 30M)
- 20M (this does NOT complete the 10M feature)
- Double Score
- Light Special
- Light Extra Ball
- Only one WABAC feature is possible:
- The following**** Puzzle features are possible:
- 2M Drops
- Spin N Win
- Rocket Shots
- Back In Time
STRATEGY
So, what have we learned and does any of this change Keefer’s strategy that Mystery Select is normally preferable to Super Mystery Select?
Assuming you can choose between two (2) MS awards or one (1) SMS award, how do the numbers work on a risk/reward basis? (In reality, over time you would probably get slightly more than 2 going for MS exclusively because of the risk of ‘stranding’ a MS on your last ball while going for a SMS.)
Advantages for going with Mystery Select
- Mystery Score: MS averages 12.5M versus 11.25M (22.5M/2) for SMS
- Bonus
10X and Bonus Hold available via MS, but not SMS
- Same award, but double the chances by collecting MS twice instead of SMS once:
- Light Extra Ball
- Light Special
- Light Laser Kick
- Tri-Ball
- Save Nell
- Possibility of 50M+ per round
- Not available via SMS
Advantages for going with Super Mystery Select
- Spin N Win
- NOT available via MS
- Possibility for big points if you are good at shooting the right ramp.
A 'Wash' (or Difficult to Evaluate)
- 10M MS vs 20M SMS
- Remainder of Puzzle Awards
- If you get one you don't like, it doesn't move you any closer to the next puzzle.
- Remainder of WABAC Awards
- If you get one you don’t like, it still moves you closer to other WABAC features you may care about
TBD
- Double Score
- Is there more than meets the eye?
Based on this information, I would probably continue to stick with Keefer’s strategy of going for MS instead of SMS. However, in the next two episodes we will discuss some reasons why you may want to go for SMS under some conditions.
*The fact that lighting the three top rollover lanes also advances SELECT is easily overlooked and isn’t addressed in the manual or in the guide.
**Many of these awards are already listed in the guide; however, in most cases it isn’t indicated whether the awards can be won from Mystery Select, Super Mystery Select, or both.
*** All WABAC features EXCEPT “Bomb Millions” and “???” (Mystery Award) can theoretically be completed via Mystery Select.
**** The two Puzzle features not listed in the 1993 guide are award Extra Ball and Special. Although the first four puzzle features are in pseudo-random order, Extra Ball (if available) will be the fifth puzzle and Special (if available) will be sixth. The current (unfinished) puzzle is never awarded via SMS.
Did you know:
- Initially, Spin N Win rotates between 5M, 10M, 15M and 20M (12.5M average per right ramp shot). However, beginning with the third time it is started the values are 10M, 20M, 30M, and 40M (25M average per right ramp shot).
- You get 5M for starting a Puzzle feature via the left scoop, but not for starting one via Super Mystery Select.
