Quoted from Deaconblooze:Looking good, really thorough. I'm curious if you're logging your hours for this? I'd like to know how long something like this would take.
I don't have an official log for the hours, but I've probably put about 15 hrs. into it so far over the past week. I'd anticipate that it will probably take me 40-50 hours to complete it but that's a total guess. I just hope everything works when I get it back in the cabinet!
Quoted from PaulyB18:Looks great Mike. First time checking out the post and looks like you have made a ton of progress. Think its a great idea getting all new light sockets. Excited to see this in person when its completed.
Keep the pics coming and best of luck!
spfxted said:maybe contact Jim (Honda). He is an unbelievable talent at this sort of thing.
You should print new wrappers for the coils...
Thanks Paul! Custom coil wraps would look nice, and I may indeed look into using them.
Jim, I've been following your work for a while and you really do incredible work! I'm impressed with your setup as well as how quickly you can do a swap. This is my first swap and I appreciate your input. I haven't screwed down the 3 big drop assemblies for the reason you mentioned, and the other assemblies are not screwed down tight so I suppose I can take them off if they get in the way.
I do have a couple questions though from when you did the Centaur. First off, Did you prep the bulb sockets by sanding the tabs or applying some type of flux before soldering the braid on? I just want to make sure the solder sticks well to the new lamp sockets that I ordered.
Also, what did you use to clean out the star rollovers? I used a scalpel to clean out the extra clear but they still seem a bit "tight" in comparison to the originals. I'm just worried that they'll get stuck during gameplay and I'm actually going to order some extra star rollovers and may re-do them. Thanks!
-Mike
