Flash Gordon drain coil not working. Game won't end.
Started 1 year ago by All_Hail_Ming in forum Technical help.
Forum » Technical help » Topic
  • Started 1 year ago by All_Hail_Ming
  • Latest reply from JDawg
  • 135 karma points were scored in this topic
    Hello again. Here is the second problem I'm having with my FG pinball. The Outhole Kicker won't kick out the ball and Left Out Lane switch doesn't recognize any roll over, even after cleaning and adjusting the switch.
    When the ball drains, and the game play is supposed to be over, it just sits there and acts like it's still in play. The ball will roll into the drain and sit on the coil and switch, but not end the game play.
    I've tried cleaning up the connection tab, checking the coil and switch, but no luck. Even if I try to manually flick the switch, nothing.
    The Outhole Kicker coil is good, but that is as far as I can go with it.
    Any ideas here? I can't remember the tests for this issue. Thanks.
    Have you check all fuses? Take them out and check continuity with a mm
    First put game into switch diagnostic mode and test the switches...Any that don't register you have either a bad switch or bad wire or a broken diode...To test which, with game still in diagnostic, short the two wires together on the switch in question...does it register then? You can use a piece of jumper wire or a flat blade screw driver between two switch lugs with wires on them....Careful don't touch anything else while you're under there with power on. You can also test the diode....With game off, put your meter on diode test. Put black lead on banded end, red on non banded. Make the switch. You should see .6V on your meter.
    I checked the fuzes. All good. I put it in test mode and the coil 01 (outhole kicker) works. It kicks out the ball every time. I also put it in switch test mode and 0 come up bad.
    When I'm still in switch test mode, the switch doesn't seem to matter. I can open or close it manually and the system doesn't see either.
    OK, I found it. The problem was on the MPU. Bad cable connection in the J2 connector. Reseated them and it works.
    I taped down the one of the known bad switches, opened the back box, wiggled the wires on the MPU and there it was. The J2 connector is where both those switches landed.
    So, why does something like this happen? Works fine, never gets moved around, then cuts out?
    Still can't explain why the right slingshot coil doesn't work though.
    The connectors oxidize over time....The mechanical tension of the connectors loose their hold over time...Vibration of the machine loosens things and cracks solder joints. It's just the nature of the beast.
    Thanks for all the info. I have the same problem I will let you know if this fixes it for me. For me it's an intermittent problem that comes and goes.
