F14 Tomcat plastic needed
Started 12 months ago by Vinnypin in forum All PinballAll Pinball.
Forum » All Pinball » Topic
  • Started 12 months ago by Vinnypin
  • 4 Pinsiders participating in this thread.
  • Latest reply from MadPole
Tilts/ ignores / abuse
Sharing and favs
Help us build a pinball game knowledge base by linking topics to the games discussed in them!
    12 months ago
    Brought a customer his new WCS94 today, and found out his f14 tomcat has a few issues.
    Fixing the board set right now, but he's also got a broken plastic in the back of the playfield. Kind of hard to describe, and I don't have a picture of it, but it is literally the plastic that is all the way back against the back "wall" of the playfield, and is basically centered in the playfield as well. I'd guess it's about 6" from left to right, and maybe an inch and a half to two inches front to back.
    Figured I'd throw this out there in case anyone has replaced their old set with a new repro, and has one to spare. I'm willing to listen to anyone who would sell one of these. Please let me know what condition it's in, and what price you'd be asking for it (shipped of course) and I'll get back to you.
    Vinny
    12 months ago
    I think I have the piece you're looking for. It's a bit wavy, but can easily be straightened out. There is one small scratch on the lower left side, but it in the black only and can easily be touched up from the back side.
    I'll send it to you free of charge if you can help me out with a problem I'm having with my F14.
    12 months ago
    Don't mean to hijack a thread, but Madpole, would you happen to have a right slingshot plastic for the F-14...I have been looking for one for months...
    also, whats your issue with your F-14?
    12 months ago
    Yes, this is a difficult one to find by itself. I've seen it in complete plastic sets that have come around every so often. GL.
    12 months ago
    I already gave both of the slingshot plastics to a fellow Pinsider in California last year.
    I'm at my wits ends. It wasn't a long trip to start with.
    My F14 will no longer kick out a ball to start the game.
    It's running a new Rotten Dog MPU board. I've replaced the snubber board that controls that solenoid and a flasher. I can hear the relay cycling on the snubber when the ball should be kicked out.
    I can take the coil to ground any where along the path from the coil, through the diode board to the J12 connector and get the coil to fire.
    If i jumper between the J12 connector and the center tab of Q25 i get a weak pulse on the coil.
    The game was running fine with the new MPU for a couple of weeks. The problem started when I was turning on all my games to prep for a party.
    I'm out of ideas. Anybody out there have an idea of what to check next?
    Thanks in advance.
    11 months, 4 weeks ago
    Is this the piece you're looking for?
    11 months, 3 weeks ago
    Hi Madpole.
    Sorry to take so long to get back to you. Yes, that's the one.
    As for the problem with your eject to trough issue, I'm not quite sure what to make of that.
    You say that you can manually get the coil to fire when jumping the transistor ground leg to a good ground? Yet, in game play, it has a weak pulse?
    I have just recently found a bad connector that caused a similar problem... I'd say that the logic seems to be working if you get a weak pulse, but that the connection isn't quite good enough to get all the juice to the coil.
    I know that sounds simple, and may or may not have any bearing on the issue, but like I said, I've found connector issues to be the number one issue for bad or intermittent (weak) switch/coil/lamp functions.
    Realizing it's a new board, I will say this with nothing against Rottendog. But I recently purchased a new NiWumph board that was faulty from the manufacturer... had a bad batch of capacitors on it, which caused all sorts of problems when installed in the game, and only after it warmed up!
    Is it at all possible that your Rottendog board could be at fault? We take for granted that these things should work perfectly right out of the box because they are new, and granted, in most cases they do.. but for the most part, these parts are being produced by smaller companies, with small budgets, and of course, may not have the capacity, time, budget to always check quality control etc... Again, nothing bad meant towards Rottendog or their products. Just a caution that maybe the board could be the problem even though it's new. I have the experience to say it happens.
    Good luck.
    Vinny
    let me know what you want for the plastic, I'd love to be able to put it in my customer's hands.
    Vinny, I'm outta town for one more week.
    PM me your address and I'll send it out no charge when I get back.
Wanna join the discussion? Sign up for a Pinside account, or sign in if you already have one.
© 2001-2014 Pinside.com All rights reserved. Jump to topRSS feedsHelpContactCookiesDesigned by Keeple
