Quoted from Blake:Ok so I have done some more trouble shooting. I will be rebuilding the PS but in the meantime I figured I would just keep working at it. These are all the connections that I can see are supposed to be made from these two BRs. Keep in mind that one of these BRs has nothing connected, I believe that the is BR2. Also I have traced one of the BR1 outputs to a fuse located on the underside of the playfield. This looks to be a modification as there is a three fuse block and then this fuse installed beneath it. Pictures below.
Blake
J3 pin 8 is connected to what I believe is BR2
J3 pin 9 is not connected to what I believe is supposed to be from BR2
J3 pin 11 is connected to what I believe is from BR1
J3 pin 12 is not connected to what I believe is supposed to be from BR2
J2 pin 4 is connected to a lamp on the coin door not the solenoid bus from what I believe is BR2
J1 pin 5 is connected from what I believe is BR1
J1 pin 7 is connected to what I believe is BR2
J1 pin 8 is connected to what I believe is BR1
image-988.jpg 393 KB
image-209.jpg 455 KB
EBD LE has 3 fuses under the pf. It looks like somebody moved the center fuse of the 3 fuse bank and added a single fuse holder in it's place? Perhaps the fuse clips are bad or tarnished from overheating. Somebody really hacked the shit out of this game. Placing the bridge rectifier on the transformer mounting plate was an actual Bally repair shown in the service manual back in the day. I learned this from an EBD that I got with a similar situation you have there. To save time, the op or tech would mount the rectifier to the transformer plate, heat sink compound should have been used, yours doesn't look that way. Another reason for this type of repair is the lugs on the rectifier, these wide lugs will not mount to the -54, you need the solder mount version. Also the bad rectifier should have been removed from the board. Here's a pic of what was in my EBD.
If I were you, I would try to find a working -54 or get the new repro A2 power supply from Marco for $99.
These pics are from the first EBD version,so the wire colors will different than the LE. The second pic is the same board where the high voltage diodes were changed without even removing the board from the game, what a thing of beauty
