Can someone with a Dirty Harry machine please go into "Magnet Test" and see if the test actually works.
I have a game here that the magnet works in solenoid test and the optic switch 42 also works in switch test mode however in "Magnet test" the test does not function properly.
When entering "Magnet test" the box for optic 42 switch is lit and for a split second the magnet is energized and the box for the magnet is checked on the DMD, then the magnet turns off and the box on the DMD for the magnet goes off. Once this happens the magnet is no longer energized and by activating switch 42 optic no longer energizes the magnet or indicates so on the DMD display.
Please don't ask if the coin door is closed. This is not the problem.
I also removed the CPU and put it on a WPC test fixture with the same results. I then used a different CPU and again received the same results. I have revision 2 CPU software. The only thing common between the two different CPU boards is the PIC. chip which happens to be a shifted bit chip.
I am wondering if the "Magnet test" actually works in another machine or maybe the test portion has a bug seeing both the magnet and switch work fine in individual tests.
Anyone with a machine that could confirm proper operation of the "Magnet test" would be highly appreciated.
Thanks in advance
Jerry Clause
Gameroom Service
