Closest LED to an Incadescent
Started 1 year ago by mandelbloom in forum Technical help.
Forum » Technical help » Topic
  • Started 1 year ago by mandelbloom
  • Latest reply from SunKing
  • 165 karma points were scored in this topic
Tags
No tags yet.
    Whats the closest thing to an regular lamp from coin taker. I am thinking the frosted warm white vs coolwhite? They also have the retro but I think that will be to bright.
    Retros look like incandescent bulbs
    for GI or inserts?
    some people like the retro's for GI lighting, as it probably does look closest to incandescents, but personally I prefer the frosted domes in warm white. I haven't tried it yet, but Pinball Center just came out with an "old white" domed LED. That one holds some promise I think.
    For inserts, I'd say the 90 degree from cointaker are closest.
    -Hans
    For GI..and its a LOTR which really looks best with regular bulbs so I am trying to get something close to that as I like the less heat and not having to worry about the burning out Inserts area already done with some Pinball Lifes and look nice.
    are the retros directional like other LEDs?
    I have been very happy with the warm white frosted.
    I would go retro from Cointaker...they are pretty close to incandescent bulbs.
    Phoebe
    44/47 are not directional 555 are not either because the have the new dual contacts
    I use mini warm white from cointaker for inserts and backbox. For GI I still prefer incandescent.
    Retros are supers with a clear dome, I believe. Pretty decent lateral dispersion, though I suspect marority of light output is on-axis.
    If you want something that is close to standard bulb, make sure you go with WARM WHITE. Anything else is too blue, IMHO. Cointaker has warm white frosted for $0.69 each. The 'warm white retro' LED's also look good, but are a bit brighter and cost twice as much ($1.29 each).
