thanks.
-jon
Would probably depend on the circuit design. The TIP is a transistor and probably had additional biasing. The IRL is a logic level Mosfet. Its gate is designed to be turned on by a simple 5V logic signal.
can this be replaced with any other TIP transistor? i have everything from 31-36, but oddly no 32 on hand..
Problem with a TIP36 (and anything above a TIP32) is it's a physically different/larger package (TO-3P vs TO-220). You would have difficulty mounting it properly to dissipate the heat generated. And a TIP31 is the compliment to a TIP32 so you can't use it in its place (even though it's in the same package.)
viperrwk
RS no got.
https://greatplainselectronics.com/search.asp?pg=1&stext=tip32&sprice=&stype=&scat=
http://www.bigdaddy-enterprises.com/electronics/e_transistors.htm
I could keep going but you get the idea...
viperrwk
This page was printed from https://pinside.com/pinball/forum/topic/can-a-tip32c-be-replaced-w-a-irl540n and we tried optimising it for printing. Some page elements may have been deliberately hidden.
