I started having problems with BSD mist multiball--whenever I hit the ball off the magnet, and then drained one of the balls, it would act as if both balls had drained. Then it would go crazy and start giving me 2 balls per play, probably because it doesn't know how many balls there are.
Anyways, I did a switch test, and sure enough switch 82 (the long range opto that detects if the ball is on the magnet) is not opening and closing like it should. Tested the receiver using the remote control technique, and then the switch closes. Checked the transmitter using my camera phone, and it is on. Deduced the problem was with the 24 switch opto assembly.
I took out the assembly, didn't immediately notice anything wrong with it. Decided to reflow some suspect looking solder points. Put it back in, and the switch worked! Played one game, same problem with mist multiball. Went back into switch test and its not longer working. Now I'm thinking something is loose. Took the board back out, low and behold I see that there is a component not fully attached to the board. I'm guessing I must of inadvertently closed the connection when I reinstalled it the first time, then it vibrated apart when I played a game.
I've attached a photo of the damaged board. According to the manual, this part is Part Number 5551-10890-00, Inductor 10 μH. It is L1 on the schematic, also attached.
After a bunch of hunting around, it turns out its not as simple as replacing this part. A lot of forums say some inductors do not work. I am completely clueless when it comes to electrical theory--can someone help me find a suitable replacement part? Thanks!
